Results 1 to 4 of 4
Thread: Vr acclaim engine light
    1994 Holden Commodore Executive VR
    Jan 2011
    Toowoomba
    Default Vr acclaim engine light
    anyone got any ideas as to why my engine light comes on at random. i can go days wihtout it comming on, then out of random comes on. it does not flash it just stays on. you can drive for 10mins at times before it will come up. car runs well still. been driivn it for last 3 weeks like it.beleive if there is a problem it should flash my engine light dont. just comes on at random. any help be grateful.
    Jan 2011
    Toowoomba
    vs commodore
    Oct 2009
    Tamworth NSW
    Mate Id first try doing an error code check to make sure theres no problems with the ECU or the engine management systems etc.If theres a problem somewhere,and its setting the engine light off,it should have set and logged an error code.Heres a link to a page that shows you how to do this simple test to check these codes..
    ---Checking error codes VR/VS (Revised)---
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    G'Day John, could be one of the shift solenoids playing up in the trans.....do like Bretts says as every time the engine light comes on it "should" leave a code....hope the tail-lights are workin!!!!
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Changing the light in aircon control VR acclaim
    By VR_Acclaim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2010, 09:06 PM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. VR Acclaim ABS OFF Warning Light
    By pjwilki in forum General
    Last Post: 27-05-2009, 02:42 PM
  5. VS Acclaim missing under light-medium load
    By blamesociety in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2007, 01:28 PM
