Results 1 to 9 of 9
Thread: engine noise vr v6
    vr v6 commodore sedan
    Mar 2011
    meckering
    Question engine noise vr v6
    hi all,
    the other day my trusty sedan developed a rattly noise in the engine bay.
    Sounded like its coming from water pump area at idle when at highway speed it
    does not seem noticeable. Am trying to fix myself so did a bit of homework and
    ended up putting a new tensioner pulley on- no fix, new water pump-no fix,
    new alternator- no fix. Am thinking of 3 areas now timing chain, power steering pump
    or a friend suggested harmonic balancer. anyway I take the serpentine belt off and noise gose away
    put it back on noise comes back. when I turn the power steering pump pulley by hand from 10 o'clock
    to 2 o'clock I can feel and hear a slight ticking . when the belt is on and I turn the steering the sound
    seems to increase but sond still seems to be coming from timing area.
    Im in a quandry and hope someone has had a similar experience and can help me
    thanks in advance
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    With the belt on, eyeball the HB whilst the engine is idling...it should appear to run pretty true...no wobbles...
    What happens if you turn the A/C on....sound change?
    PS pump should be pretty smooth to turn by hand.
    Remember sound travels - it may appear to come from the timing chain area but actually comes from something far away.
    Sounds like you are doing your detective work in a methodical and elimination method which is the only way to go. Good Luck.
    Final thought - the balance shaft bearings can wear and rattle in high mileage engine....if you are over 300,000km you should consider this.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    harmonic balancer more than likley a lot cheeper and easier than timing chain
    Mar 2011
    meckering
    Am in the process of installing a new power steering pump. Unfortuneately Ive recently had a shoulder reconstruction
    and am waiting on a friend to replace the hardened hose that runs from the pump tank to the steering rack ( probably
    the original hose) before I can bleed and test. Will let everyone know as it progresses
    Havent tried it with the aircon on but will when up and running again
    engine has only 185000km
    Mar 2011
    meckering
    alright finally got the powersteerin pump installed and guess what... noise is still there. So I guess it gets narrowed down to
    the harmonic balancer or the timing chain. Ive done as much as I can do and have booked in to the mechanics on Monday.
    expensive exercise in trying to do it yourself and maybe in hindsight I should of gone straight to the mechanic but I
    guess ive got of new gear now that should be good for a few years to come. will keep all updated
    Mar 2011
    meckering
    went to the mechanic today and he told me it was the harmonic balancer. Will have to wait and
    see if thats all it is in a couple of days
    Mar 2011
    meckering
    yep harmonic balancer was the culprit $281 later. then to add to it had oil in water when I got them to reverse flush radiator, turns out
    that the inlet manifold gaskets have seen better days. mechanic said they only last about 10 years. so there you go in hindsight I probably
    should have gone to the mechanic straight away and it could have saved me a heap of cash, but as they say shit happens. Hope this can help
    someone out there with a similar problem
    1994 Vr berlina 3.8 v6
    Mar 2011
    Christchurch, NewZealand
    Hey there tom slick, did your car sound like a diesel when you say it sounded rattly in the engine bay? Mine sounds like a diesel, maybe timing chain or lifters? or tappets?
  1. [VID] VU V6 engine noise.
    By smash0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2010, 05:17 PM
  2. 190 kw engine noise
    By dbcoop sv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-02-2009, 10:32 PM
  3. Help with engine noise
    By vl8 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-02-2006, 12:33 AM
  4. engine noise. need help
    By matrix in forum Car Audio
    Last Post: 15-11-2005, 11:06 PM
  5. V6 'S' Engine noise
    By 87VLCALAIS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-01-2005, 12:13 PM
