Results 1 to 3 of 3
Thread: Vs won't start
    Vs Calais
    Nov 2005
    In a house down the street
    Default Vs won't start
    Car on 2 occassions would not start. First occasion car would just crank over but wouldn't start, let it sit for about 10 minutes and it start very sluggish rough idle then normal.
    Second occasion car just cranks over on a couple times it's tried to start but just dies.
    I have had previous problems with the CAS which has been replaced on 2 occasions. Did a fault test but came up with no errors. Checked all wires leading to CAS nothing wrong. Checked if any corrosion on connectors to coil pack all clean ( again a previous problem).
    Have not been able to hear if file pump primes and never have heard it before. ( mechanics have commented on it in the past on how quiet it is.)
    Since I have changed all fuses and relays fuel gauge shows empty and distance to empty is showing 0.0
    The amount I have spent on tow trucks on this car is getting beyond a joke.
    Any ideas would be grateful
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Commodores need a good battery...if in doubt buy a new one.
    If your car will not start after 5 seconds of cranking, you need to stop and figure out why it is not firing......is it no fuel...no spark.... Keep cranking and you are only going to kill the battery.
    But my initial thought is that your battery is not up to it.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    it sounds like your fuel pump may need replacing
  1. Wouldn't start when warm, now won't start at all
    By karwalski in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2010, 06:18 PM
  2. Where to start
    By shach1971 in forum General
    Last Post: 01-11-2009, 06:21 PM
  3. VT Won't Start!!
    By man_84l in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2009, 05:12 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
