Results 1 to 10 of 10
Thread: VR Transmission
    vs berlina
    Apr 2009
    port pirie,SA
    Default VR Transmission
    Hi,I have a 6/1994 VR sedan.I need a new trans but apparently there are 2 different ones.How do i tell what one i have?The guy at the mechanics said there is a sticker on the bell housing but mine is missing.is there another way to tell?thanks
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    Auto? my understanding was all VR's ran 4l60e.
    Manual? t5 5spd
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    vs commodore
    Oct 2009
    Tamworth NSW
    They are all known as 4L60E transmissions from VR onwards,the easiest way to be sure it will fit your car is to check out the electrical connector on the transmission.If it has 12 pins its a VR transmission.If it has 13,its a VS transmission,they will both physically bolt up to either car,but the electrical connectors are wrong,so this makes the boxes non interchangeable..For VR you need a 12 pin connector on the transmission,for VS you need a 13 pin connector on the transmission..
    Heres a list of the different transmissions used.I got this list off the net,so Im not too sure how accurate it is,but still the easiest way to tell is by counting the number of electrical connector pins.
    VN used the 700R4.
    VP used the 4L60.
    The VR and onwards used various setups of the 4L60E transmission,which is an electronic version of the 4L60.
    4L60E 4HDD = 1994 VR V6.
    4L60E 4HDB = 1994 VR V8.
    4L60E 5HDD = 1995 VR V6.
    4L60E 5HDB = 1995 VR V8.
    4L60E 6HDD = 1995/96 VS V6.
    4L60E 6HDB = 1995/96 VS V8.
    4L60E 7HDD = 1997 VS V6.
    4L60E 7HDB = 1997 VS V8.
    vs berlina
    Apr 2009
    port pirie,SA
    vs berlina
    Apr 2009
    port pirie,SA
    is there any difference between the connector plugs on the v6 4HDD and V6 5HDD?If my friends Vr has a 4HDD can he put in a 5HDD?
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by amanda View Post
    If they both have 12 pins in the connector,it should be fine.Definitely check that first.
    vr v6
    Aug 2009
    If the sticker is missing there is a number stamped on the drivers side of the gearbox.In this link 700R4 / 4L60 Transmission Information/ History | GM Truck Headquarters scoll down the page and see the gearbox with a red arrow pointing to where the numbers are.It is a yank site so dont pay attenion to the numbers or where it says it is on the passengers side.The numbers should be 4hdd... or 5hdd...
    vs berlina
    Apr 2009
    port pirie,SA
    vr Commodore
    Aug 2006
    I have a 4HDD trans out of a VR sedan that has only done 166000kms. Never towed anything and always had a trans cooler fitted. I am asking $350 for it so if you are interested pm me.
    Never be afraid to try new things; remember amateurs build the ark while professionals build the Titanic.
    vs berlina
    Apr 2009
    port pirie,SA
    I tried to pm you but it said you need to delete some messages.i'll ask my friend if he's interested and let you know.Thanks
  1. radiator differences 2 transmission lines or 4 transmission lines...
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2010, 12:10 PM
  2. VE Transmission
    By shelldrake in forum VE Holden Commodore (2006 - ?)
    Last Post: 02-01-2009, 04:49 PM
  3. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  4. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  5. vr transmission
    By dantheman78 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 09:12 PM
