Results 1 to 13 of 13
Thread: vs transmission 3-2 hard kickdown problem
    1995 vs executive
    Mar 2011
    Default vs transmission 3-2 hard kickdown problem
    I have a 1995 vs executive v6 which is having a problem with downshifting from 3rd to 2nd.
    If I accelerate and it has to shift to second there is a small delay and then it bangs into gear quite hard. Could this be the 3-2 shift solenoid? I have never worked on auto's before so any help would be much appreciated.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    1995 vs executive
    Mar 2011
    No transmission light on, so will it have a fault code?
    The car changes up fine, it even kicks down from 4th-3rd and 2nd-1st fine.
    oil level is good.
    Is this not a common problem?
    1995 vs executive
    Mar 2011
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    1995 vs executive
    Mar 2011
    No delay. Everything else is just as it should be apart from the 3rd-2nd kickdown. If I am being really picky it makes a slight transmission noise under hard acceleration in 1st and second also.
    1995 vs executive
    Mar 2011
    so I guess that nobody knows. Am I really the only one who has had this problem?
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    So did you replace the 3-2 sol yet?
    1st gear - Sol 1-2 is on Sol 2-3 is off
    2nd gear - Sol 1-2 is off Sol 2-3 is off
    3rd gear - Sol 1-2 is off Sol 2-3 is on
    4th gear - Sol 1-2 is on Sol 2-3 is on
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    I had this problem and it got worse the sol where fine, get a service and they'll tell u whats wrong, mine was the bands, I've had mine adjusted bit my box just gave way so yeah what collies ur oil aid it's black ur clutch packs are rooted
    1995 vs executive
    Mar 2011
    Not yet. I was waiting to see if anyone had the problem and knew for definate what it could be. Thanks for that info its very helpful, making me think even more that 2-3 is sticking on. Would you have any idea if mine is the grey or white plug 3-2 solenoid?
    Quote Originally Posted by The1 View Post
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    i can't remember if you search you might find it, what model box is it, should have a sticker on the housing in the engine bay, XHDD
    1995 vs executive
    Mar 2011
    cheers. I will have a look in the morning.
    vs executive s1/ vz berlina
    Mar 2008
    Try changing the 3-2 down shift sol, the one at the front of trans, driver side.
  1. VP Problem Hard to Start and Black Smoke
    By NOOBshoes in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2011, 07:25 PM
  2. How hard is it to service a transmission?
    By V8commodore_chick in forum General
    Last Post: 04-02-2008, 09:13 PM
  3. VS Caprice hard start - intermittent problem
    By jonh_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-06-2006, 09:19 PM
  4. vs transmission stoping painful kickdown
    By andrewmac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2006, 04:38 PM
  5. Hard to Start Problem
    By raven_au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2005, 10:17 AM
Tags for this Thread
