Results 1 to 10 of 10
Thread: high ratio roller rockers or cam?
    NONE
    Feb 2011
    Alaska
    Default high ratio roller rockers or cam?
    hey guys, I've got a 94 vr berlina, 2nd stage shift kit (auto), sports exhaust soon to have CIA.
    i was wondering which would be better to get performance and cost wise. either a bigger cam or high ratio roller rockers, also as far as i can tell they do the same thing... let more air in longer... correct me if im wrong (most probably am)
    Haters gon' Hate
    STL17's Avatar
    STL17 is offline Whipit
    VS STATO , VP EX COP
    Aug 2009
    townsville
    Rockers are best bang for buck unless u know how to pull engines down and install cam
    tuning done by THE1 A+++++ tuner
    And powering it by MACE
    Build it to handle the MANG
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Rubbish.
    Cam in every way shape and form.
    Rockers are the dodgy way of doing it. Nice way to screw up the valve train geometry.
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    You build a house from the foundation up, why not do the same with an engine.
    Go for the cam
    Nov 2008
    Smithton, Tasmania.
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Do things properly. higher lift Cam, and if necessary, lighter stronger ROLLER rockers to suit combo. Pair them with the camshaft.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    Nov 2008
    Smithton, Tasmania.
    Standard ratio rockers are the go.
    Problem with the V6 is the low static compression. Limits the choices with cam's.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Years ago i started with RR's. not one of the best decisions i made, but still made some gains. Later went for a bigger cam and wished i did it in the first place
    Therefore im with some of the guys above.... chuck a cam in there... dont be shy either, put something reasonable in there
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    5.0L VS EXECUTIVE
    Mar 2010
    Have a look at the range of cams here, these guys been making more horsepower from the same v6 engines for longer than us.
    ZZ Performance
    96 VS ute, L36 Auto.
    Pacies, 2" catback, 18" RJR Shaddows
    No more V8'S, GT35 TO GO ON SOON
    NONE
    Feb 2011
    Alaska
    Quote Originally Posted by RUF 231 View Post
    yeah i wouldnd be putting anything pissy in there, definatly lumpy lol
    thanks guys, pretty sure ill be getting a cam now
    Haters gon' Hate
  1. [Ecotec] Identify high ratio roller rockers
    By Shearer in forum V6 Development And Modification
    Last Post: 06-02-2011, 09:17 PM
  2. [VIC] WTB: High Ratio Roller Rockers for VR V6
    By matt089 in forum Swap / Wanted to Buy / Trade
    Last Post: 30-09-2009, 05:20 PM
  3. High Ratio Roller Rockers
    By VSSECO in forum V6 Development And Modification
    Last Post: 20-03-2008, 11:18 AM
  4. High ratio roller rockers
    By blaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2006, 11:35 PM
  5. High Ratio Roller Rockers
    By Griggsy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2003, 10:11 PM
