Results 1 to 4 of 4
Thread: Changed the front springs
    VS 5L Ute
    Feb 2011
    Traralgon
    Default Changed the front springs
    Hey peps,
    I just changed my front springs in my vs ute and meanwhile as i was compressing them a few ball bearings fall out, i think there from the top of the strut em i correct?
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Yep, the strut top bearing, which sits just inside the bottom of the strut top bushing. If ball bearings were out then they strut top bearing, and probably bushing too, are totally screwed, so you probably want to change them soon as you can. I used the SuperPro strut top bushing and bearing (all comes together) and would recommend them. Also I'd be doing both sides at the same time.
    vn executive s2 v6
    Jun 2008
    they would be from the bearing in the top of the strut, one of mine did the same thing i cleaned them regreased inside and reinstalled.
    i havent had a prob yet, probly should have replaced them but muee
    i had the garage check everything when the did a wheel allingenment and they said every thing fine
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    yeah if you can put them back together then you could probably get away with them but eventually it will just come apart again and need replacing anyway
  1. [NSW] WTB VU front v8 struts/springs and rear springs standard height
    By dreammist in forum Swap / Wanted to Buy / Trade
    Last Post: 23-12-2010, 11:55 AM
  2. [VIC] ssl rear springs and sl front springs with struts
    By shnap2nd in forum Parts And Other Items For Sale
    Last Post: 30-07-2010, 11:21 AM
  3. King Springs low front springs, are they lower then FE2?... oh and the rears..
    By mike49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2010, 07:32 PM
  4. Vr commodore front springs the same shape as VK front springs
    By bang_chong in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-05-2010, 08:07 PM
  5. cheap place in adelaide to get front springs changed
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2006, 12:55 PM
