Results 1 to 5 of 5
Thread: vs ute problem
    Fizzman is offline Fizzman
    VS Commodore Ute series III 1999 v6
    Aug 2009
    Default vs ute problem
    hey guys lately when i put the foot down past 2000 revs on my vs ute its starts coughing and chocking (sounds really unhealthy) and then it picks up but going up hills is the worst..
    the transmission still changes smoothly so doubt its that.. cant see any obvious leaks. .
    any ideas?
    it is due for a service.. it has pacemaker extractors, exhaust, greenfoam chip, cold air intake and k&n panel filter if that helps. .
    cheers
    VX SS
    Jun 2005
    Check the fault codes and also ensure all spark plugs and the leads are firmly attached.
    1997 VS Ute series II
    Nov 2010
    Newcastle NSW
    hey man sounds very similar to all the mods m car has. i had this problem when i first got it and changed my filter over to a k&n pod. took all the lumps and choking straight out. maybe a shagged filter how long since its had a clean? checked all the fauly codes etc?
    VL Commodore
    Dec 2008
    Aug 2009
    ok guys ill check leads filter now.. been a while since filters has had a clean..
LinkBacks (?)
  1. 03-09-2011, 11:15 PM
  2. 01-06-2011, 08:58 PM
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. VK v8 breathing problem/oil pressure problem
    By Bookanun in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-12-2010, 03:02 PM
  3. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  4. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  5. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
