Results 1 to 7 of 7
Thread: VR Faulty Instrument cluster
    GSR
    GSR is offline
    Feb 2004
    Default VR Faulty Instrument cluster
    I've lost digital read outs for trip computer,litres per 100 ks, odomter etc. Needle gauges work ok. Anyone familiar with this? Do I need a new instrument cluster?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Have you got a mate that you can borrow one from or maybe try the fuse or a loose connector?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If the ODO is not showing when the car is off the cluster has lost 12 v power via the orange white wire in the 4th plug.
    and 3 Dangerous non ABS VN's
    GSR
    GSR is offline
    Feb 2004
    The ODO is on when car switched off but only half of numbers showing. It started on the left of the three displays, then the middle one went now I'm slowly losing ODO, kms left display on the right hand side.
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    The plastic conector membrane develops hair line cracks same as the analoge dash..
    Very fine and low temp soldering iorn and alot of practice..
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by GSR View Post
    Most probably 2 things - 1. The LCD's are dead now and will need replacing. 2. the white fascia holding the LCD screens in place has failed releasing the pressure needed for the screens to work - it will need glue and some know how to fix.
    GSR
    GSR is offline
    Feb 2004
    Thanks for your input guys. Much appreciated.
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. vt instrument cluster
    By stubang in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2008, 07:55 PM
  3. VN Instrument Cluster
    By Bugsy27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2008, 03:46 PM
  4. Instrument Cluster
    By petert in forum Electrical Wiring / Questions
    Last Post: 10-04-2005, 12:28 PM
  5. new Instrument cluster?
    By Trewman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-02-2005, 04:02 PM
