Results 1 to 5 of 5
Thread: vs - not changing gears
    vt commodore
    Mar 2011
    wollongong
    Default vs - not changing gears
    Hi, if someone has any ideas as too why a vs commodore 6cyl gearbox wont change gears automatically....it will change if you manually do it, also i have been told that the upshift solenoid needs replacing, could this be the issue. cheers
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VB SL/E
    Dec 2008
    Full manual shift kit fitted????
    If not then check the error codes, my guess would be one of the shift solenoids.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could also be the power control module part of the ECU or the Throttle position sensor ....but as stated above, do a codes check Checking error codes VR/VS (Revised)
    Edit....I seem to remember that there is a fuse that can blow and cause this problem.....fuse number 9 in the passenger compartment??
    vt commodore
    Mar 2011
    wollongong
    Thanks guys for your input, i will check all those things.
  1. auto not changing gears
    By Hamma2x in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2010, 12:01 PM
  2. VN not changing gears smoothly
    By Nevyn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2008, 10:40 PM
  3. changing gears in auto
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2006, 08:18 PM
  4. Stalling when changing gears
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2005, 06:46 PM
  5. changing diff gears
    By HDT_aero in forum General
    Last Post: 06-05-2005, 04:08 PM
