My power windows appear to be shorting out when the car is hot, and by hot i mean not the engine the body e.g when it's been in the sun, the windows will either not work at all or they will work for a short time then the circuit breaker underneath the steering wheel will heat up and they will stop, if I take the circuit breaker out and cool it down then put it back in the windows will work again for a few seconds untill it heats up again and stops, i've replaced the circuit breaker more than once it makes no difference, this only happens when the body of the car is warm and will stop after a few minutes of driving when it cools down. I'm guessing it's shorting out somewhere but have no idea where
Has this ever happened to anyone else, where do you think the short is most likely to be
nah the buttons don't stick at all
