primo
- Sep 10, 2009
- 30
- 0
- 0
- VS Commodore
Yep............ it's true. The car has been playing up for weeks. Every morning is a challenge to start her up. Usually turn the key and no sound or cranking over. There is power to the rest of the car and it has a new battery and CAS. Usually get it started by swapping over relays, so I believe there is a short somewhere between the ignition and the relay(haven't checked the error codes yet).
Anyway this morning, different problem surfaced. Got her started (relay swapping again) but now I can't switch off the bloody engine ! I swear the car is possessed.........my mum has called in the priest!
I stop the car, turn the key off and pull it out, but the engine stays running.........i can only switch it off by pulling out the ignition relay...............
Any idea before I take her to the auto electrician? Given the ignition relay has been playing up for weeks, it is an obvious cause. There must be a fault somewhere in the electrics, could even be a faulty ignition barrel ?
