Results 1 to 5 of 5
Thread: VS Commodore - Engine won't switch off !!!
    VS Commodore
    Sep 2009
    Default VS Commodore - Engine won't switch off !!!
    Yep............ it's true. The car has been playing up for weeks. Every morning is a challenge to start her up. Usually turn the key and no sound or cranking over. There is power to the rest of the car and it has a new battery and CAS. Usually get it started by swapping over relays, so I believe there is a short somewhere between the ignition and the relay(haven't checked the error codes yet).
    Anyway this morning, different problem surfaced. Got her started (relay swapping again) but now I can't switch off the bloody engine ! I swear the car is possessed.........my mum has called in the priest!
    I stop the car, turn the key off and pull it out, but the engine stays running.........i can only switch it off by pulling out the ignition relay...............
    Any idea before I take her to the auto electrician? Given the ignition relay has been playing up for weeks, it is an obvious cause. There must be a fault somewhere in the electrics, could even be a faulty ignition barrel ?
    1996 VS Caprice V8. 1996 Proton satria.
    Jul 2008
    Seaford, Victoria.
    I'm guessing a fault in the barrel? if so, you'd need to replace the barrel, key & BCM
    The all new TATA Nano, India's $3000 low cost car, Runs on Chicken Vindaloo!
    VS Commodore
    Sep 2009
    all sorted............auto electrician found that the ignition module(not the barrel) just under the steering wheel had started to corrode around the connecting terminals so it wasn't sending the correct kill signal when you pulled out the key. Replaced it and all good now.
    05 VZ Equipe
    Mar 2011
    Melb
    wow the engine wouldnt turn off.
    Mechanic: "Id invest in some ear plugs for when you sleep".
    05 VZ Equipe
    20 inch PDW C-16 rims | Growler CAI | 2x12 inch Kicker subs | 300.1 Kicker Amp | Xtrons 7" 2 DIN DVD PLAYER | 2 1/2" Exhaust
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Quote Originally Posted by primo View Post
    I`m glad you got it sorted.
    I`m glad we got a thread that didn`t have CAR WON`T START lol. lol.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  1. VP commodore SECURITY ON OFF SWITCH
    By tickyxr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2010, 08:54 PM
  2. Electric Aerial Switch For Vs Commodore
    By danielj_au99 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2010, 09:10 AM
  3. Engine Start Switch ???
    By COMMY VP 666 in forum Electrical Wiring / Questions
    Last Post: 22-04-2009, 07:59 PM
  4. WH Statesman engine oil pressure switch
    By nigels in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2007, 03:48 PM
  5. Engine Cooling Fan Override Switch - Using an A/C Switch
    By Maiku in forum Holden Commodore How-To's
    Last Post: 14-03-2007, 10:59 PM
