Results 1 to 5 of 5
Thread: vr-vs wheel width
    01 VU SS UTE
    May 2005
    Moree
    Default vr-vs wheel width
    hey all what would the widest wheel be i could get on the rear of a lowered vr or vs ute without any modification. thanx in advance
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Probably get different answers from everyone but I had 19x8's with 245 rubber on my old vs ute without a drama. They only ever sometimes scrubbed a little on the inside when going over steep driveways at an angle etc. Mine was pretty low too. This is it to give you an idea...
    Hope that helps,
    01 VU SS UTE
    May 2005
    Moree
    looked sweet to i was hoping to squeeze a 9" wide underneath but duno how ill go
    VR 5.0 ltr Ute
    Nov 2009
    Beenleigh, QLD
    I have 18x8.5's with 235's on and mine dont scrub at all, even when loaded with 500-600 kilos in the tray, and mine's lowered too, depends on the offset of the rim...
    "I realize you were young and inexperienced at the time, but in hindsight you should have chosen your parents more wisely."
    Aug 2008
    NSW South Coast
    Quote Originally Posted by Matty o View Post
    9's are probably doable, but the max in my experience. I'd be trying one on there before you buy a set of wheels. As above, the offset will be critical. Probably a little easier with 235's aswell. Also make sure all your rear rubbers like upper and lower control arms, panhard rod etc are all in top condition to reduce the amount of sideways slop in the rear end.
  1. Clubsport wheel width?
    By jhawk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2010, 02:36 AM
  2. Clubsport Wheel width?
    By jhawk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2010, 10:00 PM
  3. VE Rim Width
    By JDW5560 in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-02-2010, 02:05 AM
  4. About Width
    By wilca014 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-07-2006, 07:03 PM
  5. Rear wheel bearing seals (width) drum V disk
    By digisol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2005, 11:42 PM
