Results 1 to 7 of 7
Thread: steering wheel buttons
    vs executive
    Feb 2011
    brisbane
    Default steering wheel buttons
    current steering wheel is getting a bit ratty so if i got another i figured might go for this
    HOLDEN COMMODORE VY STEERING WHEEL (eBay item 260750520003 end time 21-Mar-11 20:00:00 AEDST) : Cars, Bikes, Boats
    i like having the buttons but would i still be able to use them if it fit and how?
    bluetooth headunit?
    thanks
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    youd have to wire them all up yourself if it's for a vs, as they didn't have any buttons with those functions, it would depend on your headunit and carphone setup to.
    vs executive
    Feb 2011
    brisbane
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    i havn't done so myself and prob wouldn't want to with an airbag, even if the connector is the same most likely the resistances will be different and upset the system.
    PS wont fit, easy done with a search VY to VS Steering Wheel
    vs executive
    Feb 2011
    brisbane
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by tekkado View Post
    bluetooth headunit?
    thanks
    That wheel will NOT fit a VS.
    Steering shaft diameter/spline changed at VT. (VT air bag will fit a VS wheel)
    EDIT: Just read The1s post.
    VL Commodore
    Dec 2008
    If you can get a VS One, it should not be that hard to wire up, you just need to get that little box that receives the Signals from the Steering wheel too. I wanted to do this a while ago and found out it wont be too hard to wire up, and if you can find a head unit from a VS that had button controls then you just splice the wires into what they should goto on the unit using the wiring diagrams on the gregories book to help.
  1. Steering Wheel Buttons
    By cavz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-12-2011, 07:34 PM
  2. Vy steering wheel buttons
    By m_unit in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-02-2010, 07:27 PM
  3. vt steering wheel buttons
    By 90magpie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2009, 09:04 PM
  4. VY Steering Wheel Buttons
    By teagan_150 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-11-2008, 06:43 PM
  5. Steering wheel buttons.
    By Lloyd1986 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-01-2007, 01:52 PM
