Results 1 to 8 of 8
Thread: vacuum controls dont work help needed
    macca69 is offline macca
    Vr ute
    Jul 2008
    South east Queensland
    Default vacuum controls dont work help needed
    vacuum controls dont work inside car fan works gr8 the vent controls donot work ihave changed them with another one that worked still nothing were to look from here
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The first thing to check is the thin vacuum hose that connects at the rear of the intake manifold, make sure it is in good condition and connected properly. There should a one way valve on that hose, check it's operation.
    MY RIDE
    Vr ute
    Jul 2008
    That is all good the vacum caister seem good to ? idont no were else to look
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try removing one of the vacuum hoses with the clear plastic elbow from the heater switch under the steering wheel and to the left - have engine idling - there should be strong vacuum from one of them.
    If not there is a vacuum problem.
    Attached Thumbnails Attached Thumbnails vacuum controls dont work help needed-hotvacswoff.jpg
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Mine does not work too.
    I noticed when cleaning the air intake that someone had blocked off the small vacuum hose at the rear of the intake manifold with a small length of hose with a screw in the end.
    This may indicate a leak somewhere.
    There is a small round plastic thing attached to this hose which would be the one way valve. From there it branches two ways, one going into the cab.
    Might go downstars and see if it works after connecting that hose back up the other day.
    VL Wagon
    Aug 2010
    Adelaide, Australia
    any car that uses vacuum to adjust the vents really shows what a cheaply made car they are.
    its such a horrible idea and has no benefit whatsoever!
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    The clear hose was not connected as per Hako's photo above.
    Hooked it up and now all is working.
    While I was there, had a look at the speed alert that also was not functioning.
    The connector for it was not plugged in.
    Now that works too
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Good to hear it's fixed....
  1. vn heater controls? anybody else had the vacuum lines not work and are they hard to f
    By steveabbott in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2012, 12:39 PM
  2. VR Vacuum leak from Aircon controls
    By combatantsomeone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2010, 01:25 PM
  3. for those that dont understand vacuum
    By ari666 in forum Tuning
    Last Post: 17-06-2009, 01:06 PM
  4. snapped vacuum hose for heater controls....
    By roon_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2009, 03:51 PM
  5. Removing the Vacuum Block from the heater controls?
    By ProggerPete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2006, 06:41 PM
