Results 1 to 6 of 6
Thread: Engine Swap - Vn engine into Vr ute
    VN
    Mar 2011
    Gold Coast
    Default Engine Swap - Vn engine into Vr ute
    Hi guys, i know its illegal to put an older engine into newer car, but i have a vr ute with no engine lined up and a vn with kmac adjustable front suspension, 5spd box with heavy duty clutch etc.
    i was wondering if a vn series 1 engine will bolt straight into a vr - s ute. As far as i know the engine has a different radiator hose pip that curves around and goes on top of the vr engines, i can get roady no problem but is there any chance you can make a series 1 3.8L into a series 2 the same as they have in vr's?
    I guess mainly, will the engine, suspension and box bolt straight in?
    My mate has an engine crane so pretty keen to get started
    Reece
    vs commodore
    Oct 2009
    Tamworth NSW
    Yes it will pretty much just bolt straight in there,but is the vehicle going to be registered at all,or is it already registered,If it is then I wouldnt bother with that engine it as the vehicle wont be roadworthy with that engine fitted,and wont pass rego,or will be put off the road at some point if already registered,so it will just be a big waste of your time and money,another thing too is if you got involved a crash,the insurance companys wont pay up because of the unroadworthy condition of the vehicle,so it just not worth it.
    Mar 2008
    check with qld roads or whatever you have up there
    i know in nsw that should be fine to do as they both comply to the same emission standards of that time
    eg the emission standard from back then may have spanned a few years
    but check with relavent authorities before you do , dont just take my word for it
    VN
    Mar 2011
    Gold Coast
    ok cheers, so there is no chance of converting a series 1 engine into a series 2 and getting around the emissions problem?
    Stupid qld rules, makes everything so different
    vs commodore
    Oct 2009
    Tamworth NSW
    Im not to sure,I know of guys in NSW who have tried this before and have not been allowed to register the vehicle with an older engine fitted,Ive heard they use the engine number to determine the engine type,year etc,and if its older,it wont pass.If that is the case,then the only way around it would be to change the engine number stamped into the block.
    VN
    Mar 2011
    Gold Coast
    ahh k true, sounds a bit dodgy for me, think i will stick to vg, guy has one running with 5spd for 1k..
    Just another quick question will my suspension, diff etc i have running on my vn fit straight onto vg ute?
    Also i have been told all utes have lsd's is this true or is it just the s pac models, thanks so far guys been very helpful
    Reece
  1. Vx gas engine swap
    By VryNeat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2010, 11:04 AM
  2. VT to VN Engine swap.
    By VN Commodore Executive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2010, 06:02 AM
  3. from vp to vr engine swap
    By skweek in forum V8 Development and Modification
    Last Post: 11-12-2008, 09:10 AM
  4. Possible Engine swap
    By DUK13Y in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-12-2007, 11:19 PM
  5. engine swap
    By tregs in forum V8 Development and Modification
    Last Post: 25-11-2007, 07:08 PM
Tags for this Thread
