Results 1 to 12 of 12
Thread: vs starting problem
    wub
    wub is offline
    vs
    Mar 2011
    perth
    Default vs starting problem
    hey guys this is my first problem with my beloved vs and ive gone through several different things to see if i could get it to work but i cant.
    when i go to turn the car it cranks but like slowly and intermittently as if the starter motor is really struggling to crank it over. i check the relays and they are good. hooked a battery pack to the leads. took the starter motor out and tested it and it seemed to gun. then when i tested it hooked up in the car wiring it worked again but when i put it back in the car it just sounded like it is struggling to turn it over. possibly csa? all the electrical side seems to be good so im just clutching at straws here.
    maybe the starter motor works out but its just a bit nackered so its not fully cranking the car over?
    any help would be much appreciated
    thanks
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    still could be a burnt starter motor, under load is different to free reving. Is your battery all good?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As above....probably the battery which has to be in good condition.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    wub
    wub is offline
    vs
    Mar 2011
    perth
    yeah was thinking it was sweet to free rev but mihgjt not have the balls to turn the motor. hooked the battery up to 4wd jump start pack that was fully charged so yeah that should be all sweet. i have a spare cas so would it be worth putting it in? my mate said theres no point because it should crank over even if its stuffed
    vt s s1
    Mar 2009
    Would still crank with faulty CAS, wouldnt slow the crank down, as above sounds more battery related, only as you havent mentioned anything about the battery, have you tried a new one? Or tested the one in there?
    wub
    wub is offline
    vs
    Mar 2011
    perth
    i think the battery is cactus but i have used hooked up those 4wd jump start packs to it with full charge and still no love
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The jump packs will only 'assist' a sick battery to start and cannot be relied upon....if you think the battery is cactus then I'd say it is.
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    ok i was having the same problem it ended up being all the wire's from the battery to the frame and to the motor all inside the wires were burnt out so i went to the wreckers and got a hole set of wires off a VZ and now mine is better then ever
    wub
    wub is offline
    vs
    Mar 2011
    perth
    ill try my hiluix battery in it and see how it goes. otherwise a whole new set of wires? big job?
    Mar 2010
    Cockatoo Vic
    Here are the wire's that i changed i just added extra because i had another set of lead's it didn't take to long 45 minute's
    VN
    Mar 2009
    unlikely it's the wiring harness but not a huge job imo - i've done it before. Worth trying a good battery i guess, nothing to lose, but more than likely a bad starter i reckon!!
    Happy to lend a hand, for a few coronas (no carlton dry thanx)
  1. vr starting problem
    By azzabatch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2010, 01:15 PM
  2. Car starting problem
    By Denno in forum Electrical Wiring / Questions
    Last Post: 21-07-2009, 08:09 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. VS starting problem
    By mrnathan in forum Electrical Wiring / Questions
    Last Post: 06-06-2006, 09:46 PM
  5. VT Starting Problem
    By Waynus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-03-2005, 11:35 PM
