Results 1 to 4 of 4
Thread: Vr t56 conversion 5 ltr
    vr senator
    Feb 2011
    nuriootpa
    Default Vr t56 conversion 5 ltr
    Can anyone help, im a little stuck with the wiring side of things.ive put a t56 box behind my 5ltr in place of an auto but not sure if i need a manual loom?can i utilise the auto loom and if so how?
    anyone done this conversion???
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    U will need a manual chip for the ecu. As far as the speed sensor, im unsure. It should just be a proxy tooth pickup. Wire it up to suit like a normal proxy sensor and you will prob need a speeedo corrector kit from jaycar. bridge the P switch out. shouldnt be too much moore then that. but if u wanna make life easy get a manul box loom to plug in, save you alot of guessing.
    Reaper
    vr senator
    Feb 2011
    nuriootpa
    VR Moded 400HP,6Spd www.cardomain.com/id/chaserx
    Jun 2009
    Queanbeyan
    Default t56 conversion
    You can get a custom loom for around $500 according to my check list or you can do what im doen & give your auto electrician a call to see if they can wire it up.
    In hind sight, an auto electrician should be able to wire up your new loom, with your old 1 & bits & peaces, cheaper. Im running a cable to the boot so it will be less hastle for my mechanic, when it comes to servicing my vehicle, which currently has brand new parts in it.
    Can you let me know how your going with it because its been 6 months, since your last post & im looking into taking my VR into a transmission shop in the next week or 2.
  1. L67 conversion OR 5L conversion in vs commy??
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:54 PM
  2. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  3. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
