Results 1 to 16 of 16
Thread: Changing brake pads - Do it myself or pay mechanic?
    VS Executive '96
    Mar 2011
    Sydney, Australia
    Default Changing brake pads - Do it myself or pay mechanic?
    Hey guys,
    New member here, recently bought my first car (VS executive '96) and cannot wait to do it up slowly. I need help, The brake pads need replacing and cannot decide whether to go to a mechanics and spend a fortune or go down to autobarn and buy my own brake pads and do it at home.
    If I do it myself, it will be my first ever time doing this and without guidance from a father figure will need to work it out. What I'm asking is, should I do it myself and just get a guide off the net or get a mechanic? and as stupid as it may sound, where abouts on the car do I place the jack to jack it up?
    Cheers.
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    If you have the patience and the room and tools to do it. I say do it yourself. Will save yourself a lot of money. When you jack the car up make sure you get the chack on the chassi. Also don't take the wheels off unless you have the car supported by car stands. By yourself the manual and the pads and everything you need to do for the swap. Plenty of people to help you along and it will save you a fair bit
    vs commodore
    Oct 2009
    Tamworth NSW
    I suggest you get a workshop manual to follow,it shows you all you need to know to change the brake pads,it also shows most other jobs that you can do yourself so you can save money.You can learn a lot about your car from it...
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    If you have to ask then yes - pay somebody to do it for you. At the very least have somebody who knows what they are doing to guide you thu it. It's an easy job but the downside is pretty horrendous if you screw it up.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Haydz's Avatar
    Haydz is online now 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    its your brakes. the only thing slowing down your car. your taking your life into your own hands by toying with it yourself. unless you know what your doing i wouldnt touch it.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    I say get the workshop manual and look up some how-to's and familiarise yourself with everything involved and ask as many questions as you want on here. Once you've got it all figured in your head, and have the tools and manual and a print out of a how-to or some notes, you should be right. If you're confident enough after that then do it, if you're unsure pay someone to do it
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Yeah at least have a crack at it yourself, just putter around on a back road to test them, don't go over about 20km/h to start with so even if they don't work you can handbrake to a stop.
    Ronald Reagan (1986)
    5.0L VS EXECUTIVE
    Mar 2010
    The best advice you can get will be this
    1. Go and buy yourself a GREGORYS manual for your car.
    2. Also buy or borrow a set of car stands they are usually around 50 to 70 dollars a set, NEVER NEVER work on a car just sopported by a jack.
    3. When you remove the wheel slide it in approx halfway under the sil of the car, This is a safety safety if the stand fails for some reason the wheel under the car will stop it from crushing you and or damaging the car.
    4. NEVER WORK ON A CAR THATS JUST SITTING ON A JACK ALWAYS USE A CAR STAND.
    See here for car stands
    NEW AXLE STAND JACK STANDS 6 TON CAR STANDS (eBay item 370482610982 end time 09-Apr-11 14:17:35 AEST) : Cars, Bikes, Boats
    96 VS ute, L36 Auto.
    Pacies, 2" catback, 18" RJR Shaddows
    No more V8'S, GT35 TO GO ON SOON
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Here is a How To on the brake Pads
    VX front Brake pad Change How To Detailed
    Here is a how to on placing you car on stands and using a jack
    How to Jack up your car and put it on Safety Stands
    But Yes also grab a manual. Best thing ever, saved me 1000s
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Do it yourself once you have read all the procedure,take it nice and slowly and safely.Make sure you have a g-clamp to push the pistons in.And make sure you have the callipers held up with a strap so the brake line doesnt get damaged by the weight of the callipers hanging and make sure the pins go back into the correct position,when I have replaced brake pads I found out that them little suckers like to pop out.
    94 VR Commodore Executive
    Mar 2011
    Yamba
    Like everyone else has said to do on the safety side is good advice. I would also firstly jack up the car & remove a wheel & check for grooves on the disc if there are any & they are deep(2mm) or so & if there's a lip on the disc I would get new disc's they are not hard to replace there will be plenty of how to's on this site for doing this . There's no point doing the pads if your disc's are worn. You will find new discs on the net are the cheapest just make sure they come from a good supplier ( DBA) or the like.
    Happy learning the art of home repairs
    theslippery1
    commodore
    Aug 2009
    australia
    id say have a crack at it its a very easy job only takes about 10minutes a side once you know how to do it, as already stated buy a manual and stands and once youve learnt you will never have to pay to have it done again.if your discs need doing theyre easy too just follow the manual.
    vs commodore
    Feb 2011
    Another thing you'll need to know if it's your first time,is that you should bleed your brake system of any air that might have got into system.There's how-to on this forum somewhere (i think!!)with pictures to help you better understand each step .Good luck mate
    VS
    Mar 2009
    Quote Originally Posted by Blakvsexec View Post
    Definitely invest in a gregory's, money very well spent.
  15. #15
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    i agree wuth reaper( if you have to ask get some one who knows to do it for you.....brakes are somthing you should get done by those in the know
    Reaper
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  16. #16
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    People are too scared of brakes, I say do it yourself only if you have some mechanical aptitude. If you don't know a hammer from a screw driver, then at the very least, have someone there that has done brakes before.
    I wouldn't bleed them though, there is no need to bleed them after a pad change. It can cause more problems if you don't know how to bleed brakes correctly and know what you are looking for.
    Visit my Facebook page
  1. changing brake pads
    By PKM09 in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-05-2009, 05:40 PM
  2. changing rear brake pads
    By excalibur in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2009, 04:10 PM
  3. Changing your brake pads
    By vnv8driver in forum Holden Commodore How-To's
    Last Post: 04-11-2008, 09:03 AM
  4. Changing Brake Pads
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2006, 11:53 PM
  5. Changing brake pads
    By me_011 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-06-2006, 03:56 PM
