i have done a search but not found a definitive answer
i have a vr 3.8 wagon auto, i can get my hands on a whole vs sedan all running but stuffed body
ive found out the vs engine mounts are the same and will bolt up no problems, i will be running the vs auto as well,
so if i run the vs wiring loom, ecu and bcm with wiring, ignition barrel and i have the keys from the vs can you see any problems or anything else i may need to do
will i need to change all the under bonnet fuses etc from the vs, if its a straight forward swap i will go ahead with it
are the vr / vs radiatiors the same , would i need to swap the dashes over
does the aircon pipes line up to the vs aircon comp
thanks guys
