Results 1 to 3 of 3
Thread: VR Commodore Stalls When Warm. Help!!
    VR Executive
    Mar 2010
    Default VR Commodore Stalls When Warm. Help!!
    Hi
    This forum been great for alot of the fixing I've needed for my VR 1994 Commodore Series 1 but Series 2 Motor.
    Just this weekend I Replaced:
    Alternator $259
    New coil Pack (one)$60
    New battery $145.00
    New Crank angle Sensor $82.00
    The Problem the alternator was gone was only putting out 0.5 volts and battery was on its way out.
    Which caused stall when i turned lights on and wouldn't start and ran really rough.
    (replaced alternator and battery)
    3 and 6 coil pack the 6 wasn't sparking so could be the cause of the random stalls. so we replaced the coil pack.
    The car would stall when it reach half between H and C on the temp gauge. and would start till it cooled down, so the clues said Crank Angle Sensor. (Replaced the CAS)
    Car Runs till half between H and C on the temp gauge then turns it self off its not like stall its like just turns off, We don't know wtf is happening, I've already spent shit load.
    When friend last took it for test it happened again but when he touched the plug to the DFI module and when back to start it again it came back, if when it was still warm. but don't if he was right, it could be close to the problem.
    Fuel pump and fuel Relay is Fine and work perfectly.
    Friend Common thing is DFI module for the coil packs.
    If its not the DFI what else could it be?
    We also tested the imoboliser and the key is fine.
    ECU gives codes
    Code 13 - Oxygen Sensor (O2) - No Signal ----- was Replaced Couple Months ago New not second hand so should be Fine.
    Code 24 - Vehicle Speed Sensor (VSS) ----- Don't why that would be problem Speed reads fine
    Code 36 - Vacuum Leak ---- Vacuum Leak Could be anything
    Model VR Commodore 1994 Executive
    Pacemaker Extractors
    2.5 Exhaust
    States cold air intake.
    Series II motor
    I'm in Epping Victoria 3076 District.
    First Post And thank you to anyone that may have clue would be Great.
    Regards,
    Mark ( AKA Zkai)
    94 VR Commodore Executive
    Mar 2011
    Yamba
    Check the vacuum hoses on the throttle body also might be worth giving your throttle body a good clean & the IAC sensor on/in the TB for the best results remove the TB (how to's on this site will show you what to do ) if you have compressed air use this to clean IAC With the vacuum hoses check for cracks/splits.
    Hope this helps.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quickest cheapest and easiest thing to do is get a 2nd hand DFI module from the wreckers.....or remove the plug under the module and check that the connectors are not corroded which can happen when degreasing the engine and degreaser gets in the connector and eats away the connectors. Also check the earth to the module. Do checks before buying the module as it probably is just a bad connection.
    Good Luck.
  1. vs commodore stalls on right hand turns.....???????
    By Cpt Awesome in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2012, 04:50 PM
  2. VN stalls/wont start when warm
    By REWIRED in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2011, 10:17 PM
  3. Vp nearly stalls when warm
    By Auzzie_VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2009, 06:03 PM
  4. VR Commodore Berlina Stalls Auto Stock
    By HoldenCommodores in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2008, 09:05 PM
  5. VH commodore stalls when warm
    By bigfella99 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-11-2006, 09:36 AM
