Hi guys im new to the place so i will introduce my self quickly, My names Miikey im from Mt Druit and i drive a Silver VT Berlina and a Gold HSV VR V6, both are pretty much standard altho the VT Has 20's on it,
anyway, in my VR im having a problem with the gearbox or motor, not 2 sure which 1 it would be but i can start the car and drive it for awhile then the gearbox/motor light comes on on the dash and then the gears slam into gear, i have changed the gearbox and changed the ECU but it still happens,
any feed back would be greatly appreciated because its a beautiful car and i want it 2 perform at its best
Thankx in advance
Miikey
check error codes will probably come up code 19 21 or 22 TPS sensor related
Probably a silly question to ask but sillier things have happened, Does it have a shift kit? Does it kick into gear when your giving it some or just randomly
As delco said check your error codes, if you don't know how check this link out. Checking error codes VR/VS (Revised)
i did the codes and it came up with 12 and 13, which sensor would 13 be and where is it located??
Bump back to the top anyone got a idea?? Iv changed rear end control arms n bushes n the ecu but it's got
Me stumpt
1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
