hey
can someone please do a how to on changing the ecu and loom for a vr manual conversion.
i dont really know where the loom goes and there not much info on how to do it.
thnx
unplug everything and plug the manual loom in :P
abit more info please
bump bump bump
hey mate ok start at the left kick panal thats your ECU unplug that then there will be a little wight plug that connects it up to the body loom then go to your engine bay feed the loom past the fire wall unplug everything that needs to be to remove the engine loom its better to take the motor and box out with the loom and everything connected just make shore that the gearbox selector is off and the tail shaft is dropped from the diff it makes it so much easier the change it to the manual box run the new loom while the motor is on the ground put it back in and done my advice is to take pics of everything as you do it so you know were everything goes but make shore you flywheel is suitable and dont forget the plastics and stuff on the inside
^^wow, all you wonderful punctuation made that paragraph so easy to read.^^
But yourself a Haynes or Gregorys.
That should have a wiring diagram in it that will help you identify which plugs are which on your new loom.
Once youve done that, start swapping it over.
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
so what will i have to do to get the speedo and reverse lights working?
