Results 1 to 8 of 8
Thread: VS stato supercharger
    vs
    Mar 2011
    victoria
    Default VS stato supercharger
    Hi all, can you please tell me if a V6 supercharged statesman can have the supercharger removed and replaced with standard v6 manifold and not change the harness and computer??
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    dunno about manifold swapping, but you could get crafty and take the snout, rotors & rotor plate off the charger, and bolt on a 'blanking' plate instead.....
    I suspect if I were to ask "why?"... I'd get a "p plate high powered car" response?
    VS Calais S1
    Jul 2006
    Kadina, SA
    Pretty sure you will find that a N/A ecotec has a higher compression ratio than the supercharged engine. So if you did take the supercharger off it would probably run horribly.
    vs
    Mar 2011
    victoria
    Thanks for the replies guys.
    I am told the supercharger was removed, but still has the same loom and computer. Are the supercharged engine blocks numbered in such a way that makes them easy to identify?
    Would Robotics reply cause the bottom end to develope a knock? if this was the case.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    So are you trying to determine whether your stato was factory supercharged? Check the alloy compliance plate on the firewall. For Eng it will say 'L67' if it was a fatory supercharged 6.
    The supercharged and ecotec looms are different, mainly due to the supercharged loom having the coolant temp sender and sensor at the rear instead of the front like the ecotec and it will also have additional plugs for the boost control solenoid etc. Are there any unused plugs in your loom? If what you suspect has been changed to basically make it a low compression ecotec, then its probably had an ecotec loom and pcm fitted.
    Re: the supercharged 6 running lower compression, no this wont be the cause of developing a bottom end knock. It would still run fine on an ecotec tune, but probably down a little on power.
    I may have missed the point, but what exactly is the scenario and what are you trying to determine???
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    also, engine number (stamped into block to the bottom right of water pump) will start with VS******
    vs
    Mar 2011
    victoria
    Quote Originally Posted by cander24 View Post
    well i'm trading one of my old cars for this car - its a 50th anniversary edition, supercharged v6, according to owner the super charger has been removed as it failed, so they took it back to standard V6 but didnt change the loom and ECU. It has bottom engine knock thats why im trying to work out if i need to get an engine, loom and ECU. OR just a new engine as i thought they would have had to change the ecu and loom already if the supercharge removed.
    Cheers all that are replying thanks.
    Aug 2008
    NSW South Coast
    For the work involved and amount of parts to be changed to convert it back to a N/A V6, it would have been far easier for them to have just done a complete ecotec swap. Maybe this is what they've done?
    As above though, check the first two letters of the engine number.
  1. My WH Stato L67
    By fatbats in forum VT - VX - VU - WH - V2
    Last Post: 25-09-2011, 04:40 PM
  2. [SA] Wtb: SC14 supercharger and / or VR supercharger kit
    By social in forum Swap / Wanted to Buy / Trade
    Last Post: 12-05-2009, 07:52 PM
  3. My Stato, Another first car :P
    By pedrotski in forum VR - VS
    Last Post: 24-09-2008, 12:19 PM
  4. '98 VS stato
    By r_i_d_a_h in forum General
    Last Post: 19-09-2007, 07:28 PM
  5. '95 VS Stato
    By Sphinx in forum VR - VS
    Last Post: 16-11-2006, 02:30 PM
