Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Who's 1.9.1 roller rockers are better?
    vs commodore
    Feb 2011
    Default Who's 1.9.1 roller rockers are better?
    Does anyone have any pros or cons about the 1.9.1 high ratio roller rockers From Yella Terra, FIT or Mace. Which is best,who's are ordinary ,value for dollars,etc . i'm after comparisons and other members' opinions.
    VS l67 statesman
    Dec 2008
    Yt are brand new true rolla tip rockers Mace & fit are non rolla tip remanafactered factory items , its up to you what you use performance wise you probaly wont notice a difference between them but if your going to spend the money might aswell go the Yt RR which you can get from the US delivered for a similar price for the Mace/fit RR not so long ago
    These are Yt Rolla rockers
    5.0L VS EXECUTIVE
    Mar 2010
    Its chalk and cheese.
    Like a comparrison between rooting a bloke or a sheila, the one with the bloke will do but just wont be very nice, where as with the sheila is much better and you can tell all your mates. lol
    get the yella terra ones.
    96 VS ute, L36 Auto.
    Pacies, 2" catback, 18" RJR Shaddows
    No more V8'S, GT35 TO GO ON SOON
    vs commodore
    Feb 2011
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Yea i fell screwed with mine FIT ones, if i done it again id got for the YT ones
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    vs commodore
    Feb 2011
    Do yella terra 1.9.1 have any identifing marks on em? ,so you could tell if they were correct from wreckers/ swap meets ,etc?
    VS L67
    Sep 2007
    BrisVagus
    From memory all the Yella Terra ones have it stamped on them.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    VS l67 statesman
    Dec 2008
    Quote Originally Posted by Skrewdriver View Post
    thanks vsl67, can you recomend a place in the US to get them? cheers
    INTENSE-Racing.com - Pontiac G8, Grand Prix, Bonneville, Regal, L67 3800 Supercharged Performance Products, Mods and Tunes.
    Or ZZ Performance
    I cant seem to get their web site up at the momemt
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Not sure, but you can tell the difference easily. See below.
    Quote Originally Posted by soop View Post
    YT by a coutry mile.
    Also you can't mistake them;
    VS
    To The OP:
    Yella Terra are completely different designs, they are a Roller Rocker manufactured from lighter and stronger aircraft grade alloy, with a roller bearing TIP on them. (See the photo for the difference). At higher RPM's these Roller Tipped Rockers aka 'Roller Rockers' apparently create less side load on the valves. ~ RUF 231
    MACE, FIT etc, all use the stock 'Rocker' from the factory which are re manufactured with the heads/tips skimmed etc (and all the rest) to create the higher lift.
    For a technical report on the differences between standard 'Rockers' and 'Roller Rockers' - see this article here Roller Rockers vs Rockers
    Talking to alot of modifiers and engine builders, most recommend YT products due to their obvious advantages listed above (being a stronger, lighter grade alloy, different design, true 'Roller' design which creates valve stability etc). If you are asking an opinion on which is better, I'm not going to say yay or nay to either, though if I was to buy higher ratio rockers it would be true Roller Rockers. But I wouldn't be going down that road, I'd prefer a lumpier cam. The difference would be minimal on a stock V6.
    Based on the above, the choice is yours.
    All this being said though, I would go with a different cam before upgrading rockers. But that's my preference.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    Nov 2008
    Smithton, Tasmania.
    I concur.
    Use standard ratio roller rockers with an upgrade cam for the best results.
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    I concur.
    Cost vs gain though?
    Nov 2008
    Smithton, Tasmania.
    Do it yourself and it doesn't cost any more.
    Use the right cam for the setup you want and you'll benifit from it much more then dodgy high ratio rockers.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    regrind on a stock cam $280 gain around 20% more hp throw in some new inlet gaskets and timing cover gasket and maybe a timing chain if the cam is large but not totally nessicary we run 222@0.050 0.495 lift on stock chain and springs revs to 6500 no problems
  15. #15
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Quote Originally Posted by wraith View Post
    Yes that is a definite factor, however, Cam's open up a better power range, not to mention considering longer term benefits, a higher performance camshaft, along with an upgraded and strengthened valve train, along with some suitable ratio rockers to the cam specs is probably a better choice?
    Cam with upgraded valve springs and double row timing chain + Increased compression = Torque/Kw/Power
    Rockers = a bit more power thanks to increased valve lift, but won't open up as much gain as a cam.
    In my experience with cars, you either do things properly or be happy with something that isn't really....
    1997 VS II - S
  16. #16
    Nov 2008
    Smithton, Tasmania.
    As the sayings go.
    Do it right, do it once and/or the poor man pays twice.
  17. #17
    в∞ѕтεכ √&
    Jul 2008
    NZ
    no point lifting the valve higher if the heads dont flow anymore at the higher lift LOL
  18. #18
    Nov 2008
    Smithton, Tasmania.
  19. #19
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Quote Originally Posted by delcowizzid View Post
    This is also very true.
    Point of the thing is, take the motor out, build it properly! haha.
    1997 VS II - S
  20. #20
    Nov 2008
    Smithton, Tasmania.
  21. #21
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah key is never buy an off the shelf cam grind get it ground to suit what mods you have all the way down to the diff gears and you wont go wrong
  22. #22
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    dont even have to pull it out to put a new cam in.
    Yeah exactly.
    Yeah that works too, I have heard good things about off the shelf cams. But if your building a full motor, might as well go custom to suit the whole build.
    1997 VS II - S
  23. #23
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    ive got MACE ones in mine, there better than stock ones lol... cant really compare as i havent tried the YT ones yet, but the upgrade from stockies to MACE's was huge lol
  24. #24
    Nov 2008
    Smithton, Tasmania.
    All you're doing is holding the valve open longer.
    Putting more force on the push rod, lifter and cam lobe.
    Its the most arse backwards way of doing it.
  25. #25
    VL Commodore
    Dec 2008
    Well I guess the head flow is fine since gains are still being had from 1.91 to 1.95 and from 1.95 to 1.98?
    FIT Seem to say that their rockers give the most power gain e.g their extreme ones but I think this was topped by YT not long ago,
    I just don't know how far they can go without compromising the reliability of the engine.
    I guess a good way to go would be a ported head+rocker package to get most gains MACE do a package but kinda costly. But hey for those prices you might aswell just put a SC V6 in
    and theres your power + more potential
    In terms of power output would they pretty much be the same if they are both 1.91? Whether from YT to MACE to FIT? or is there other factors
    that could affect power output.
  1. what are roller rockers :S
    By kngsv6 in forum Yella Terra
    Last Post: 04-08-2010, 11:19 PM
  2. 202 Roller Rockers
    By jakbob in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-12-2009, 08:05 AM
  3. roller rockers
    By Macka21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-01-2009, 10:22 PM
  4. 1.98:1 roller rockers
    By 17UCK! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2008, 06:26 PM
