Results 1 to 9 of 9
Thread: Vr zircon problems
    Jahwah is offline Jamie91
    VR Executive
    Nov 2010
    Default Vr zircon problems
    I'm having trouble with my aircon.
    It only turns on once you turn the power to 3 or 4. And it only comes out at feet ports not anywhere else.
    Any ideas would be greatly appreciated!
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    What happens when u select the top vents only on the a/c control switch?
    Sounds like a problem with the blower though.
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Having only 2 fan speeds means it would be your Fan Speed Resistor. Around $20 from wreckers... $40 ish from eBay. Easier replacement..
    You could have a vacuum leak or the hoses being disconnected at the Heater/Air con unit thing..
    Fan Speed resistor:
    Replacing the Fan Speed Resistor
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    VR Executive
    Nov 2010
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Quote Originally Posted by Jahwah View Post
    No matter what it's set to it only blows out at the feet
    Could be a vacuum leak; Do you hear any hissing when you start it? or turn it off?
    GothicKidd's Ride
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    My VS only blew air onto the floor and the knob to change where the air comes out did nothing.
    The fix was a vacuum line had come off.
    Located drivers side just at the end of the console (behind it) near the heater control rod.(close to the floor end of console near pedals) It was a clear coloured vacuum line that needed plugging back on to where it belonged.
    You will need a torch to see it.
    VR Executive
    Nov 2010
    Do you have any pics of the part it was? I was told this before but couldn't find it
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Here is the picture - they are the 2 clear plastic elbows on the left of pix.
    Attached Thumbnails Attached Thumbnails Vr zircon problems-heaterbutton..jpg
    VR Executive
    Nov 2010
    Thanks. Yea there both connected. I still haven't figured it out might need to take it to someone to look. Any more ideas before u take it?
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. VN Ser. II Problems!!!
    By busta-p in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2008, 03:59 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
Tags for this Thread
