can anyone on here retune my auto vr memcal so it can run a t5 manual gearbox and make it more performancy (for lack of a better word)
thnx
bump bump bump
come on surely someone can help me
Im just waiting on an adaptor for the VR memcal. If no one else gets back to you in the next few days,then send me a private message,I should have the adaptor by then,and we will go from there.
whats the adaptor for?
Its to connect the memcal to the chip burner/reader so the memcal file/image can be uploaded to a computer,once its uploaded,the memcals chip is erased using ultra violet light so its blank again,and can be written to again,then the memcal image is opened in a program,here the different ECU parameters can be adjusted for better performance/fuel economy etc,then once the tune is done,its saved and then burned back to the blank chip on the memcal.Ive been doing VSV6 tunes for a while whicxh i test ion my own car and lately Ive had a few people ask about the VR's,but Ive had no VR car to test the memcals on until now,so Ive just ordered the VR memcal adaptor so I can start to do the VR's.
ok saweet thts really good news, i have been trying to get onto greenfoam, delcowizzard and a few others but no response (i guess they are too busy).
so u can make my auto memcal work with my t5 box? can u also give a bit of a performance upgrade?
Giffo ease up on the thread bumps mate.
Use the search function before you post: Advanced Search
This has been answered before here: VR Manual Conversion
And Here: Vr ECU and Wiring Kit
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
You will need a Manual ecu. Not tune.
Originally Posted by garth
97 WRX AWD
i would prefer to use the manual ecu i have but it is impossible to find a wiring loom
