Results 1 to 5 of 5
Thread: Petrol warning light staying on???
    VR Berlina
    Nov 2009
    west suburbs, melb
    Default Petrol warning light staying on???
    Hi recently i changed a couple of globes in my vr berlina dash cluster, and im am 100 % positive i put the dash back together proparly, but now it has a problem of the low petrol warning light which comes on always within a minute of starting the car, even though it has plenty of petrol, and its reading correct on the petrol guage, so im sure its not a stuck float in the tank if its reading correct on the fuel guage. I have disconnected the battery to try and reset computer but it still does it. So is there a sensor on the tank or something? What could be doing this?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd remove the dash again and triple check the work you did - do this with the battery disconnected. It is too much of a coincidence for the fuel light to fail at the same time as you replaced bulbs.
    VR Berlina
    Nov 2009
    west suburbs, melb
    I hear ya mate, and i took it out 3 times and checked all the wiring ect....you cant stuff it up, all the plugs can only go in 1 way. But its still doing this
    vs commodore
    Feb 2011
    is car dual fuel? if mines running on lpg,the petrol light comes on and makes a warning beep approx 20-30 seconds after start-up,cos its not detecting petrol
    VR Berlina
    Nov 2009
    west suburbs, melb
    No car is on straight petrol only, it always does it 20 to 30 seconds after starting the car, even when u fill it up, shows on the petrol guage that there is plenty of fuel in tank, but still it beeps. I have not fixed this yet, i think it must be a fuel sensor or something.
  1. air bag light staying on
    By vxdriver11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2010, 12:38 PM
  2. air bag light staying on
    By vxdriver11 in forum General
    Last Post: 26-11-2010, 07:14 AM
  3. Park Brake Light Warning Staying On
    By Justanotherholdendriver in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-11-2010, 07:07 AM
  4. Air bag light staying on. help?
    By daz08 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2009, 10:31 PM
  5. Oil Light Staying on
    By VNSV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2005, 06:31 PM
