Results 1 to 8 of 8
Thread: vs commodore help and info shaking/vibrating
    1996 VS acclaim
    Nov 2010
    townsville
    Default vs commodore help and info shaking/vibrating
    hey guys my 96 VS commodore acclaim seems to shake/ vibrate alot when idling at first i thought it was missing but it just shakes. runs perfect when driving though just shakes when im stopped. any idea's what this could be? i know a fair few people that have the same problem. my compression for the cylinders is all whacked and i have been told its dirty injectors by one mechanic and my cam shaft is pitted out by another mechanic, he said just run it until it dies and put a new motor in it as a top end rebuild is more expensive then a whole new engine. although i do not want to replace the engine if it is just injectors, so if what do you guys think of this problem/situation?
    thanks, jamie.
    honey dont let them snappin turtles bite yall eyelids.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Add some injector cleaner to the fuel tank and see what happens.When it shakes does it feel like its missing,look under the bonnet when its shaking and see if the motor is actually moving around it could be the engine mounts if thats the case.
    1996 VS acclaim
    Nov 2010
    townsville
    tried injector cleaner, it does help abit so im assuming that is it but not sure. at first it felt like it was missing but its sort of a constant shaking when idling now. the engine doesnt move.
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    my suggestion, try going to repco, ask for NULON Fuel system cleaner. its in a metal tin. its a trade product but your nearest store should be able to order it. about $16 a tin, and its full strength not just the light duty sutff in the plastic containers. trust me it works. and works well.
    its a diagnostic cleaner to determine if you need new fuel system parts. so basically if it doesnt do anything for you, then it means one of two things. either your injectors have had it, or there was nothing wrong with it and its something else.
    VB SL/E
    Dec 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It could be that your engine is idling too low - when it shakes what revs are indicated?....it should not be below 700rpm.....if below 700 with bad engine mounts as VR38 suggests then it will shake. The mechanics you've been going to sound a bit dodgy.
    VL Commodore
    Dec 2008
    If coils/dfi are bad could they be giving weak spark or slight misfire and causing bad idle?
    Maybe new plugs, leads and DFI/Coils might help (Or try ones off a second hand car that idles good to rule it out before buying new?) , and take the injectors to get cleaned.
    Try another MAF Maybe?
    1996 VS acclaim
    Nov 2010
    townsville
    injectors seems like the main thing, it doesnt idle below 700rpm's and the leads and plugs are less than a year old. bosch leads and NGK plugs.
  1. Backyard Spray Job on VN commodore (Black) need info
    By Bz Kn33z in forum Spray Painting and Panel Beating
    Last Post: 16-09-2011, 01:51 PM
  2. Commodore VZ 2004 model Vibrating sound
    By samron in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-08-2010, 08:43 PM
  3. Info Re. Vh Cdt Commodore
    By greg ridgway in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2009, 03:50 PM
  4. VY commodore info wanted
    By blackwrx in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-08-2005, 10:55 AM
  5. Commodore info and specs
    By Garth in forum News/Updates
    Last Post: 23-04-2004, 05:33 PM
Tags for this Thread
