Results 1 to 4 of 4
Thread: 25 Spline diff gears into a 28 spline diff housing
    vs commodore
    Mar 2011
    burrum heads
    Default 25 Spline diff gears into a 28 spline diff housing
    Hi,
    I have a set of gears out of an old falcon borg warner diff (25 spline xh falcon i think). I need to fit these to VR/VS Diff housing. I have fitted the crown wheel to the 28 spline carrier and have started to set the pinion depth. This is where it is starting to get hard, I cant get a good marking on both the drive and coast side of the crown wheel gears. Either 1 is good and the other is bad or vise verser.
    Just wondering if anyone has successfully achieved one of these conversions.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the pinion depth will be punched into the pinion if you have a way of measureing its depth then just need a heap of shims to shim it till the backlash is correct then check pattern
    vs commodore
    Mar 2011
    burrum heads
    Quote Originally Posted by delcowizzid View Post
    Hi mate,
    Could u explain to me in further detail about what u mean by - the pinion depth will be punched into the pinion if you have a way of measureing its depth - not 100% shore what u mean by this. I understand about adjusting the backlash by changing the shims either side of the carrier. if you would prefer to talk to me by phone please call me on 0448008685.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the depth that the pinion should be set at is stamped into the pinion itself so all you need to do is measure down that far to the pinion and its done
  1. Building a 31 spline diff
    By AirStrike in forum General Discussion
    Last Post: 03-03-2011, 05:34 PM
  2. 28 Spline Diff fitting
    By Void in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-11-2007, 02:46 AM
  3. 28 Spline diff vt?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2007, 06:58 PM
