Results 1 to 21 of 21
Thread: needs help with doing est
    vs v8 statesman
    Mar 2011
    crestmead
    Default needs help with doing est
    Im in need of help i have no clue how to do the timing on my car we just put a rebuilt motor in her.can anyone tell me how it is done please. we get her to crank over but she is out and when the timing light says the timing is right she dies and wont start till she is out what the!!! i need to know how to do it
    vs v8 statesman
    Mar 2011
    crestmead
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you need to have the ecu in diagnostic mode to set timing bridge pin 5 and 6 of the top row on the aldl plug under the stearing colomn then set timing to 10 degrees with timing light
    vs v8 statesman
    Mar 2011
    crestmead
    sorry but how do i bridge pin 5 and 6 what do i use? i know where all that is just need to know how to bridge them
    vs v8 statesman
    Mar 2011
    crestmead
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    в∞ѕтεכ √&
    Jul 2008
    NZ
    paperclip peice of speaker wire anything with not much resistance
    vs v8 statesman
    Mar 2011
    crestmead
    vs v8 statesman
    Mar 2011
    crestmead
    needs help again she wont stay started at 10degrees she keeps dieing what would be the problem?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    your balancer could of spun the outer steel ring making the timing mark way off youll need to check if its still marking TDC youll get a rough idea just by turning the engine over until number 1 cylinder is at the top of its stroke if the mark is miles away its slipped
    vs v8 statesman
    Mar 2011
    crestmead
    did that and still no go made sure it came up twice but no go, and not running right still missing. im at a loss with it have tried all that and she just wont run right. do the computer need to be reset or something?
    vs v8 statesman
    Mar 2011
    crestmead
    is the timing ment to 10 degrees out after you do that and thats where its ment to run right? this is really bugging me i just want her to go
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if the timing mark hasnt moved then yes its meant to run smooth at 10 degrees then when you pull the jumper out the aldl plug it will instantly raise timing to preset levels in the ecu
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you do have the timing light on the passenger side front sparkplug lead number 1 cylinder or 2nd one back on the drivers side number 4 while setting timing
  15. #15
    vs v8 statesman
    Mar 2011
    crestmead
    vs v8 statesman
    Mar 2011
    crestmead
    в∞ѕтεכ √&
    Jul 2008
    NZ
    put wire in plug start car set timing lock down dizzy turn car off unplug wire from aldl and fire it back up .will be way easier to time when you have the timing light on number 1 cylinder rather than number 2 LOL
  18. #18
    vs v8 statesman
    Mar 2011
    crestmead
    it is on number one when i do it, number one is on the drivers side of my car
  19. #19
    vs v8 statesman
    Mar 2011
    crestmead
    when the plog is in the car wont start i put the plug in when she is started is that the wrong way?
  20. #20
    vs v8 statesman
    Mar 2011
    crestmead
    im so over this car i did all that but she is not right it drops to twent degrees i dont know what wrong with her could it be something ,aking her not run right? apart from the timing?
  21. #21
    vs v8 statesman
    Mar 2011
    crestmead
    10 degrees wont start when she is out she will start but run not good done everything
