Results 1 to 10 of 10
Thread: VS commie is really pissing me off... need some advice
    VR SS
    Jan 2010
    Ashfield Sydney
    Default VS commie is really pissing me off... need some advice
    changed the radiator, and lost a bit of gearbox oil, not much i thought, but enough to make the shift from 1st to 2nd (auto) delay a bit, or slip or something...
    so i added some gearbox oil to the trans oil pipe (no i didnt put it in the engine oil) and now its doing this weird thing when i drive it... i cant work out if the engine is misfiring, or if the gearbox is screwing up... it revs clean and nice, but put her in drive and when i accelerate it spits and backfires, kinda like a misfire but not as persistent... is it possible i've put too much gearbox oil in? its all i can think of because before i added gearbox oil, it was sweet as...
    PS. adding oil fixed the shifting problem, but now i have this crap
    any advice would be greatly appreciated
    cheers
    stuey
    VL Commodore
    Dec 2008
    VR SS
    Jan 2010
    Ashfield Sydney
    I bought dexron III from repco. if I can't figure something out I'm thinking of taking it just to get a gearbox service...
    vs commodore
    Oct 2009
    Tamworth NSW
    To me it sounds like theres either a faulty spark plug,plug lead,or ignition coil, sometimes when this happens,the engine will idle ok and rev out ok in neutral,but once its driving along with a load on the engine,either the plugs,leads or coils can break down under load and cause misfiring.Id try new leads and plugs first up,if its still the same after that,then replace the 3 ignition coils...
    EDIT:Just noticed its a V8,theres not 3 coils on a V8.
    VR SS
    Jan 2010
    Ashfield Sydney
    yea but this problem only occurred as soon as I added the gearbox oil... like, its fine when I pull up to my house, but then after I add the oil its rooted... instant... the other thing is that when its cold its fine but once hot, then its crap.
    vs commodore
    Oct 2009
    Tamworth NSW
    It might just be a coincidence that its happened at the same time.The only way the gearbox oil will cause problems is if its level is either to low or to high.Have you checked for any error codes?Heres a link to a page that shows you how to do this simple test.
    ---Checking error codes VR/VS (Revised)---
    VR SS
    Jan 2010
    Ashfield Sydney
    yeah checked error codes just keep getting 12. I'm thinking it had to be coincidence because the gearbox couldnt possibly make the car back fire. one of the leads I just found was resting on the extractor, didn't burn right through, but may have screwed it up... I'll change the leads tonight av's free what happens... other wise I'm buggered for ideas
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    When you changed the radiator did you bleed the air out of it,and maybe you did put too much oil into the trans
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My money is on the lead that's been too close to the extractor.
    96 S II VS Clubby, 96 VS S II Executive
    Jul 2010
    perth wa
    well i had same symtoms on my v6, fine when cold and in neutral but what appeared to be misfiring when hot. I concluded it was the Crank Angle Sensor because when i poured a few litres of water on to the harmonic balancer the issue went away till it got warm again. but could've been other things so i just replaced Motor and box for a new lot.
  1. Vs starter pissing me off.
    By Kingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2011, 10:16 PM
  2. vr commie alternator into a vp commie
    By illegal_____ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2010, 02:52 PM
  3. [VIC] NEED HELP ASAP...its pissing me off lol
    By bedo89 in forum General
    Last Post: 17-10-2010, 06:13 PM
  4. Your Commie Rescued by another commie
    By edals in forum The Pub
    Last Post: 13-10-2010, 08:52 AM
  5. Pissing in a shot glass
    By Sphinx in forum Jokes/Humour
    Last Post: 29-09-2006, 04:35 PM
