Results 1 to 6 of 6
Thread: Posible immobiliser probs??
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Default Posible immobiliser probs??
    Hey all my vs statesman sometimes wen i try starting it it does nothing but if i try again it starts, afer a few secs it dies will start after bout 3 trys nd runs fine after that??? Does it at least one a day
    VL Commodore
    Dec 2008
    Has an aftermarket immobilizer been added on? or do you just use the one on the factory key?
    Could be many things.
    When you say it dies does the engine suddenly shut off?
    Jan 2010
    Its a factory one. Yer it will start nd just as it starts it shuts off again if i give it a little revs wen i start it it runs fine. Just a little worried that wen i turn the key 2 start nufin happens so then i try again nd off it goes
    vs caprice
    Dec 2010
    brisbane
    does ur security light turn off
    when u put the key in i have had trouble with mine when the key battery has been dying also can have trouble with the ring around the ignition barrel to sometimes not making good contact
    Jan 2010
    Not sure havnt looked that the light what can i do 2 make the contact between the key nd barrel? Wats it mean if the key is in and the lights still on?
    vs caprice
    Dec 2010
    brisbane
    if u turn ur ignition on to reds and security light still flashing then it not triggering ur imobiliser off either could be battery in key getting sad or the ring around the igniton barrel with 2 little silver metal semi circle strips that the dot on ut key makes contact with they pop off easy can get a small flat screw driver and bend em closer to ur dot not much needed though the security light norm just single flashes unless ur car has been broken in to then flashes different to show where and what they did weather they tried to hot wire etc
  1. VS Immobiliser
    By Maxxiz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2011, 12:32 AM
  2. Vx Dash cluster level 2 into a VT with Level 3. is this posible ?
    By Madhouse_Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2010, 12:33 AM
  3. is it posible to add on to the immobilizer
    By rob drag racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-05-2009, 04:04 PM
  4. Immobiliser
    By davebart25 in forum Electrical Wiring / Questions
    Last Post: 06-07-2006, 12:09 AM
