Results 1 to 5 of 5
Thread: manual wiring loom help
    94 vr executive
    Jul 2010
    queensland
    Default manual wiring loom help
    i'm doing an auto to manual conversion, and i will be swappin the auto ecu and harness for a t5 one.
    just one question though, when i plug the ecu harness into the dash harness and the manual transmission the speedo and reverse lights should work or will i still have to do some rewiring in the interior?
    and with the engine harness are all the plugs the same except for the transmission? so will the new harness just plug into everything in the engine + the transmission?
    thanks in advance for all your help guys
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Every thing should be fine. Thats why holden uses individual looms. That way its all plug and play. If you have the manual loom then all is sweet.
    Reaper
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    no, you'll have to rewire some stuff at the inhibitor switch.
    1. bypass switch
    2. connect reverse light wire at 4 pin plug to blue wire on power button wiring
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by wamboin23 View Post
    1. bypass switch
    Arnt they all on the manual harness? asumed they were, but im not 100% as iv never owned an auto.
    Reaper
    94 vr executive
    Jul 2010
    queensland
    yea would'nt the reverse switch on the transmission connect to the manual loom?
  1. Converting a VS Auto wiring loom to a manual wiring loom.
    By johnsy_vs in forum Electrical Wiring / Questions
    Last Post: 28-08-2010, 08:45 PM
  2. VS manual wiring loom
    By t-rav in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2009, 02:00 PM
  3. manual wiring loom for vr, t5
    By harro_VR in forum General
    Last Post: 03-12-2008, 11:41 AM
  4. vr v8 manual wiring loom
    By sspsi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2008, 10:13 PM
