Results 1 to 17 of 17
Thread: VY Ecotec conversion worth doing?
    VS Commodore
    Aug 2009
    Default VY Ecotec conversion worth doing?
    Hey guys, just wondering how much it costs to swap to an ecotec from a VY into a VS?
    Is it worth doing?
    Do i need to find a manual VY ECU to go with my t5 or can i just use my existing ECU?
    Rough costs?
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Should be a fairly straight swap, just make sure you get your wiring harness and you will probably need to modify a few things such as your EGR Valve and your Coolant temp sender/sensor as they are one on the VY's. You may need to get the VY ecu and have it programmed for your Manual, shouldn't be to much of a hassle other wise.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VL Commodore
    Dec 2008
    Why do you want to take an ECOTEC out and put the same motor back in?
    Are you after a lower K motor ?
    VS Commodore
    Aug 2009
    Yeah im after a motor with lower K's. I think my rear main seal has gone (will look tomoro) and figured if i gotta take the motor out to fix that then i will look into a VY ecotec if its worth doing
    VS V6, VZ Clubsport R8
    Mar 2011
    Central Coast
    & the VY ecotec has 5kw stock then a VS Ecotec lol, you would be better off just finding a low KM engine from a VS, straight swap without messing around with wiring harnesses, or sensors.
    I would only go the VY Ecotec if I couldn't source a low KM VS Ecotec but that is just IMO.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    you can use the vy motor just put your vs manafold on it and you wont have to worry about sensors or the ecu
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    VS L67
    Sep 2007
    BrisVagus
    Quote Originally Posted by nathanVS View Post
    L67 instead, easier
    +1 best bang for buck you can get.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    VS Commodore
    Aug 2009
    L67 instead, easier
    Slight isssue, still on my P's Another 2 bloody years
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by triple b View Post
    same its the worst
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    buy an L67, put all the non super top end on, and then when your off your Ps change it back over! OR, buy an L67, leave yours the way it is ATM, and spend a bucket load on the new motor and THEN when your off your Ps drop it in knowing its gonna go off its nuts!
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by klampy View Post
    Hmm an L67 without a supercharger, would run like an absolute dog with low compression.
    Ronald Reagan (1986)
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    VX Berlina
    Apr 2007
    yea, it would. but it would help keep the license! lol
    Yeah and your dignity will die when you keep getting beaten by 1980's Ford Focus'
  15. #15
    VS Commodore
    Aug 2009
    Do I:
    -build an ecotec up ready to be charged once im off my p's?
    -build a L67 for once im off my p's?
    -or buy a vz ss once im off my p's?
  16. #16
    VX Berlina
    Apr 2007
    Last option.
  17. #17
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    304 conversion ftw.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  1. Is a twin exhaust good/worth the money on a v6 ecotec??
    By BNSVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2010, 09:44 PM
  2. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  3. Whats a cam for an ecotec worth?
    By ragrim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2008, 04:21 PM
  4. 5-spd conversion, Worth it?
    By Muffla_Man in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2007, 09:50 PM
  5. ECOTEC - Are High Lift Rockers worth it ........
    By Raptorsc in forum V6 Development And Modification
    Last Post: 26-04-2007, 06:49 PM
