Anyone have quick/good ideas to remove door moulds from a vs ?
You reffering to the door skins???
on the window sill? those are screwed on at the sides i found. Maybe post up a pic so we can see exactly wat your talkin about
The silver strip that is underneath the guard that go across both doors
Ahh i see now. well i got them off by using a thin flexi stanley knife to pull one side up, then when i could get a grip on it, just rip the ####er off. but next problem is the sealant left behind... good stuff...too good. i got it off using stanley blade again to shave off majority and MEK but carefull if you get MEK it causes cancer and can rip your paint off. maybe thinners is safer
Has been heaps of threads on this, I remember someone saying something about a caramel wheel?
Here you go
DIY: Removing those pesky door moulds
Takes awhile to do, When I did mine, I was upto my last door ,when i realised the person who last owned my car had taken the door mould off and had put it back on without taking the old sikaflex off, so i was left with 2 layers of sikaflex![]()
yes hair dryer might make it easier but if you can get ur hands on a heat gunthat the best solution. i just bought some S pack side skirrts off a wrecked spack and the skirts are bonded on with the same shit that bonds the moulds to the doors except theres alot more of it! We got them off by heating the skirt up and pulling back the lower edge of the skirt and getting someone else to get under the skirt with a flexi stanely blade while other dude is pulling up on the edge. Hope this gives you some ideas
