Results 1 to 5 of 5
Thread: Putting L67 into executive. Any tips would be appreciated.
    vs commodore
    Feb 2011
    perth
    Default Putting L67 into executive. Any tips would be appreciated.
    Was thinking of going to the auctions and bidding on a statesman with an L67 in it and putting that into my executive. Any tips on the conversion would be appreciated. Can i retain original ecu and swap the memcals? should i swap engine and G/box or would the engine with the super torque converter suffice? will be way easier.
    Just general advice is needed. If i have to use the supercharged ecu im going to retain my Bcm so i need to get them paired.
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Yes you can use the ecotec ECU and loom, you will just need the L67 memcal. You can also use your gearbox with the L67 converter (the converter is the only difference between the ecotec/L67 gearboxes).
    If the engine is from a VT onwards you will need to tap the LIM for the temp gauge sensor as the VS runs a seperate sensor for the ECU and dash. You will also need to modify the ecotec loom a little bit, but it's nothing major (mainly just rerouting some wires).
    If you haven't already, sign up to www.l67torque.com • Index page as that site has ALL the info in detail...
    VS L67
    Sep 2007
    BrisVagus
    Due to the heat that is generated with the L67 is is a good idea to change the LIM gaskets (lower intake gaskets ) to the aluminum ones before you put the motor in, they most likely need doing anyway.
    New engine mounts are a must, these engines like to eat mounts, send TTT Performance a PM for more info on mounts.
    I would also change the thermostat to a colder one, 82deg is not a bad choice, it is such a prick of a job in the car.
    As Thomas has said for a lot more in-depth knowledge head over to L67torque, the guys over there have been putting great combo's together for years. I also think that a couple people have some L67's complete that are for sale.
    Good luck with the conversion.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    vs commodore
    Feb 2011
    perth
    cheers guys. i tried to join that forum but i use a gmail account and it wouldnt let me.
    as far as im concerned its L67 out, LIM gasket change,engine mount inspection, thermo change, L67 in, memcal in. im guessing the loom will have to be modified to make up for different sensor poswtions and it will be a case of cut n solder to make things longer?
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Quote Originally Posted by cbr1234mike View Post
    Replace the engine mounts regardless if they look ok. L67's destroy the engine mounts...
    Yes the loom needs a bit of modding, but it's very simple and you will see what needs to be modified once you put the loom on the engine (do it when the engine is out of the car).
    Use another email and sign up the L67T. It has all this info that we are giving you and much much more...
  1. putting calais chrome window lining on executive
    By voja95vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2009, 10:40 AM
  2. Putting Electric windows in VS Executive???
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2006, 10:43 PM
  3. Any help appreciated ...
    By TKH in forum The Pub
    Last Post: 14-02-2006, 04:43 AM
  4. $1800 for a vn executive sedan (any ideas or tips for the interior)
    By ultimate_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2005, 11:32 AM
  5. Help would be appreciated.
    By Scholtzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2005, 10:58 PM
