Results 1 to 14 of 14
Thread: flooded drowned my vr commodore now is cranking but wont fire help plz..
    VT Commodore 3.8ltr
    Feb 2011
    Default flooded drowned my vr commodore now is cranking but wont fire help plz..
    i drove through a huge puddle and car stalled.. went to start and ticked like a flat battery... the next day i got a mates battery and motor turns over just wont fire.. air box was full of water so i dryed out with rags water was found all the way up to air intake.. i.ve checked leeds for spark and i got that... got fuel going in.. i took spark plugs out to find water so ive turned it over for awhile to get rid of the water still no luck so i put fuel in eack cyldner and turned it over for a bit again... still no luck.. cas is new and coil pack it ok... any ideas what i could try next???
    the water was up to the bottom part of the doors so electrics inside car should be fine.. no dash errors..
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    i really wouldn't no what to do but if water has got in the motor i would drain the oil and change it and the oil filter ?
    VT Commodore 3.8ltr
    Feb 2011
    there doesnt look like waters gotten into the oil...but i will do that after i get the car home
    Vz SS 6LT
    Dec 2010
    melboure
    if u got a mate with the same engine try his crank angel sensor,bit of pain 2 get 2 bro, but it mihgt b just that
    VT Commodore 3.8ltr
    Feb 2011
    Vz SS 6LT
    Dec 2010
    melboure
    it may b new bro but it wurth a shot u just never know, u seid the water wes up 2 ur door good chanse it got wet n stuffed it, n check ur iac valve
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    It could also be your spark.
    You may need to replace your Spark Leads and plugs, and maybe the Coilpack.
    When it cranks does it sound like it's almost about to kick in? or does it just keep cranking etc
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Did you get wet inside? what i mean is could your ecu have water in it? water got into mine and it stopped the fuel pump from priming and working alltogether so would crank but not fire
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    It's also possible, it got into the fuel line as well.. How high did the flood water reach the car?
    VT Commodore 3.8ltr
    Feb 2011
    it does have spark at leeds so can i rule out coil pack and cas??
    the only dry footwell is where the ecu is so i think its ok
    ive pumped fuel through the line no water found
    the water came up bottom of the door and my folt thinking it wasnt deep
    vr s1 5 speed
    Jul 2005
    brisbane
    check fuzes? spray rp7 or wd40 down the throttle body see if it starts
    (AKA TINTMAN)
    VY2 S, VS exec and VG ute
    Mar 2011
    east gippsland
    try rule out bad fuel, remove the fuel pump fuse. Try start the car with your mate spraying some start ya bastard/ aerostart at the same time and see if it fires (maybe get your make to ware a workshop glove incase of a backfire) if it fires then maybe your fuel has become contaminated
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    So you went to turn it over....it couldnt turn it over with you battery, so you replaced the battery, or put your mates battery on in series like a jump pack?
    You got it turning over, but didnt start, you took the plugs out, and found water in the cylinders?
    So essentially, you were for a while, trying to compress water in the combustion chamber, i'd be getting a compression tester ou and chcking all the cylinders to make sure you havent done any damage that would cause low or high compression and stop it from firing.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    vr BT1 5l
    Mar 2011
    perth
    are the injectors actualy injecting or can you just smell fuel, like ol mate said if water got into the chambers thats prity bad, and you will definitly have to change the oil, oil floats on water so you will never see it, run it with choclate milk as oil and it wont last very long. also check all the fuses, i think you will find if you went around with a test light it will be a blown fuel pump fuse or something stupid like that. good luck, maybe try not to drive through rivers next time haha = p
  1. VS wont start. No cranking
    By HamaTime™ in forum General
    Last Post: 30-08-2010, 03:04 PM
  2. VP - Wont Start, but is cranking over just fine.
    By Demack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2010, 08:01 AM
  3. sometimes wont start, can take minutes of cranking, but runs great
    By gsxrdan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2009, 03:46 PM
  4. Car wont start, not even cranking
    By bsbozzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2008, 08:58 PM
  5. VC SLE Wont Stop Cranking
    By pjdigital in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-04-2005, 08:51 PM
