Results 1 to 21 of 21
Thread: VE brake upgrade
    VL Calais II
    Oct 2007
    Default VE brake upgrade
    Hey guys,
    I know there are a lot of threads about doing VT brake upgrades, i've seen a few people suggest the VE brake upgrade... they say you don't have to bother about doing any upgrades the booster and master cylinder for the VE. Ive seen kits on ebay for VT upgrade (not including anything to do with booster or mc) for <600 (cheaper DIY), and VE upgrade for 725.
    Wondering if anyone has done the VE upgrade? And would be worth the extra money for not having to dick around the booster and mc, and is the VE a better upgrade performance wise then the VT upgrade?
    VR 5.0 ltr Ute
    Nov 2009
    Beenleigh, QLD
    Ve brakes and rotor are a better design, the pistons in the calipers dont need the 1" booster/master cylinder combo for one, so that makes life alot easier, and the rotors are 30mm not 28mm like the vt's and the outside diameter is bigger too i think (can't remember off the top of my head...). But is it worth the extra 100 odd dollars, to me yes, to someone else I'm not sure. Just don't try doing the vt brakes without the 1" booster.
    "I realize you were young and inexperienced at the time, but in hindsight you should have chosen your parents more wisely."
    Vz SS 6LT
    Dec 2010
    melboure
    bro i just did the vt upgrade on sat, if u do vt booster with the mod mounting braket, u gotta mod the front master cylinder support bracket,bend the brake lines for the a.b.s unit (if u got a.b.s) and when u do fit the brakes on the hub ,u gotta hav a 4inch grinder ready cos u gotta cut he brake disc shild cos the brake mounting braket holes wont line up,u cnt bend the shild,u ether remove it or just cut abit off.
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    but he is asking about wether or not the VE upgrade is worth the extra, not how to fit a VT upgrade...
    and I would also like to know how easy of a coversion the VE upgrade is. didnt know they were compatible.
    Vz SS 6LT
    Dec 2010
    melboure
    well if i had 2 cut shit for the vt brakes , u would also will need 2 cut for the ve brakes to fit,
    VR Series 2 EQUIPE
    Jul 2006
    Craigieburn, Victoria
    Yeah - I'm looking at doing an upgrade too - but I haven't heard from anyone who has done the VE upgrade.... Are the disc holes the same diameter as the VR or are shims required like the VT discs?
    Brendo169's Avatar
    Brendo169 is offline HSV Porn
    VS Senator
    Aug 2009
    WA
    im not sure about anything to with the VE brake upgrade except that you dont need to swap master cylinder and boosters as the VE callipers use two smaller pistons.
    You may be able to ask this user found here Tom's Uterus - Manual + Bench seat. he has done the ve upgrade in his ute
    VS L67
    Sep 2007
    BrisVagus
    I have just done a "VE" brake upgrade on my VS.
    I bought a kit which included the following.
    2 x slotted front 330mm front rotors
    2 x machined front VE calipers
    2 x ADR approved braided front brake lines
    2 x adapter mounts front for calipers
    2 x adapter shims for rotors
    2 x slotted and ventilated 315mm rear rotors with handbrake ring*
    2 x rear VE calipers
    2 x ADR braided lines rear
    2 x adapter mounts for rear calipers
    * the handbrake ring is pressed into the inside of the rear rotor so the VR/VS hand brake will still operate.
    The kit was just on $2000.00
    I also run a 1inch master cylinder.
    This kit bolted straight up with out any issues what so ever. It took me about 3 hours to do the job from beginning to end.
    This maybe more expensive that you had in mind, but they work so well, it is worth the money.
    To run this kit you MUST have 17 inch rims or above.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The VE upgrade kit comes with everything you need to bolt it to the car. Rotors, calipers, pads, brake lines, fluid, and all mounting hardware. No cutting required. No changing booster or master cylinder. They come in two size rotors, 289mm, or 322mm.
    I do this kit Press Releases scroll down until you get to the Commodore VE Spec Upgrade. Similar pricing as found on Ebay, but if you are close to a warehouse (I have one in every capital city) there would be no shipping involved.
    Visit my Facebook page
    VR Series 2 EQUIPE
    Jul 2006
    Hmmm ok - I doubt I'll be able to do that on my VR - it doesn't seem that it'll fit under the stock equipe rims (15"?) I'll have to measure the rims to get a bit of an idea of what size they are and go from that....
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by CRCinAU View Post
    Rim size is printed on your tire, and if you get the V6 VE brakes they will fit under 16's (well most of them) 15's, no way.
    As for not needing to do a booster/MC upgrade, i found when i done mine the pedal got a little bit squishy already had a 1inch master and V8 booster, it was in my VN V8. So I dont trust it when people say you dont need to upgrade them, altho they might be different VR/VS I wouldnt know.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by mischa View Post
    No, the kit will not fit with all 16" rims, not even sure if they fit with VE 16's on the earlier models. The caliper mount is different so it puts the caliper in a different spot to suit the different offset of the VR-VS rotor.
    Out of all the kits I have sold, not one has complained of a squishy pedal, in fact, the pedal actually got a bit harder and more responsive.
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Says on your link 298 diam fits std wheel sizes from 16", is this just there for VT up or somthing?
    I havent complained about it to who i got the kit off, just delt with it. Just letting people know of my experiences with them.
    The Daily VN T5V6
    355 VN GRP A REP
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I should elaborate. I was told by RDA that it should fit with 16", but it didn't. The car was a VN with 298mm rotors, it had VY 16" steelies and the rim fouled the caliper. That is the only VN I know of that tried to fit the kit with 16" wheels.
    This is why I say it doesn't fit with all 16" rims.
  15. #15
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    it should also be noted that the calipers need to be place on the OPPOSITE side to what they are stamped on the caliper, otherwise you cant bleed the air out .
    i helped tom do his and they are awesome. i would do this upgrade to my car if i could afford it.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
  16. #16
    turmoil117's Avatar
    turmoil117 is offline Donating Member
    vn berlina, vr statesman
    Jan 2010
    Westminster
    So you only change the front then? Why not the back brakes aswell? Or will it not make a difference
  17. #17
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The front has about 70% of the braking so the rears don't need doing. Just changing to a slotted rotor and fitting decent pads is enough.
  18. #18
    94 VR Executive & 99 VT XU8
    Mar 2005
    Melb
    i dunno, if i got the VE or VT kit, but mines basically this.
    'http://cgi.ebay.com.au/COMMODORE-VR-VS-VT-BIG-BRAKE-UPGRADE-SLOTTED-DISCS-/120707764942?pt=AU_Car_Parts_Accessories&hash=item 1c1abe52ce'
    330mm front twin piston's with slotted disc's, the pedal died down into the floor after fitting (but i had a nasty cam at the time) and it still was ok, so long as you braked with the engine revs, but I was always wanting to fit the VT booster upgrade to see how much pedal i would get back.
    i didnt use the shim's when fitting mine (didnt seem right for some reason) but the brakes themselves are great (so long as you know their limits for locking up without ABS etc).
    (also, the calipers didnt clear my 16" VY calais rims originally - so i whacked 18's on) - apparently most 16's should fit, but mine didnt. (if you have 17's you should be sweet)
    94 VR V6 - No ABS & NO IRS... a true mans steed and a 99 VT XU8 for good measure.
  19. #19
    VS L67
    Sep 2007
    BrisVagus
    Quote Originally Posted by adept View Post
    The shims are in the kit for a reason. The hub centres are slightly larger with the VT onwards front rotors. The shim is to keep the rotor from movement and to keep it center to the hub.
  20. #20
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Is the VE Brake conversion? Definitly.
    As mentioned above I have it in my ute, it pulls up so much harder, not only is it fun to mess with passengers its great when that Asshole infront of you in an Audi TT decides he wants to stop for an Orange or even green light.
    I went from worn front brakes, and seized back ones, to The RDA VE 322mm kit and reconditioned back brakes with matching slotted & dimpled rotors, my stopping distance would have been halved at a guess. Total cost was about $1200, which was with replacement reconiditoned back calipers and hoses, back rotors, Bendix CT pads, 4L of PBR DOT 4 Brake fluid, and the entire front kit.
    There is no requirement for a 1" master/booster, pedal feels is much the same as a normal VS, but I can see the benefit to have a 1" master/booster. I plan to put a 1" master/booster in, not because it needs it, but because I can and I want to milk the brakes even more.
    Installing them is simple, as Nem said remember the left caliper goes on the right, and vice versa, this was my biggest problem, which we wasted probably 4 hours on, before realising.
    The dust plate thing protecting the rotor does have to be cut or removed. Need to cut 2 -3 inches off, or drill two pop rivets out to remove it.
    If anyone does the upgrade and needs help, shoot me a PM.
    EDIT:
    Justification: It cost $1200, if I ran up the back of someone which was likely with bad brakes, my excess is $1300 plus Im still out of pocket for any damage to my car.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  21. #21
    VS 5 Litre BT1
    Jul 2006
    Site sponsor GSL do the VE upgrade kit. See here - VE Twin Piston Upgrade Package suit VB-VZ Commodore!!!
  1. [QLD] 290mm brake rotors Brake upgrade for VN/VP
    By mistergTRx in forum Parts And Other Items For Sale
    Last Post: 28-11-2010, 12:04 PM
  2. VT BRAKE UPGRADE - looking for brake line adaptors for vh to vt
    By rusty05 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-12-2009, 02:54 PM
  3. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  4. ABS and brake upgrade?
    By EGG in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2005, 10:38 AM
  5. VN to VS V8 Brake Upgrade
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 01:46 PM
