Results 1 to 12 of 12
Thread: VS Powersteering groan
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default VS Powersteering groan
    Hi All.
    Not overly knowledgable when it comes to power steering (never really touched a PS setup before)
    I have noticed over the past few weeks that when I am steering the rack/pump seems to be giving a groaning noise.
    Its holding its fluid (topped it up when I got the car a month back and level hasn't dropped since.)
    Does anyone know what could be causing this and how to fix it? (pictures would be excellent if anyone has any of the culprit part)
    Thanks Alot
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    V6 VR Acclaim
    Jun 2010
    Groaning noises are sometimes caused by the pump dying or low oil pressure / not enough oil. As you stated you're keeping the level up to it, so it could just be a case of it getting old.
    How old is the pump in it?
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by Bourbonated View Post
    I am not 100% on the history of the car (I have only had it a month or so)
    Previous owner (my father in law so I doubt he would lie to me) told me the engine had been rebuild just over 120,000k ago but not sure if that included things like P/S pump or A/C compressor etc
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Rebuild generaly wouldnt include a PS pump or AC comp. But its really what the person that owned the thing wanted to rebulid, not really a rule on what gets done and what dosent get done.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    vs commodore
    Oct 2009
    Tamworth NSW
    Theres a bush where the steering column shaft passes through the firewall into the cabin,and when this bush dries out ,it makes this horrible moaning,groaning sound when the steering wheel is turned.My car was doing it really badly when I first got it,I was told I needed new P/S pump,new rack etc,then I read on here about this noise,the dry bush and the WD 40 trick,I sprayed WD 40 on it,and it instantly fixed the noise,completely gone,and now 2 years later,its still hasnt returned.I found that its easiest to spray upwards into the area from under the car.Ive since fixed this problem on a few friends VS's ,they had been told similar things like needing a new P/S pump etc.They were very happy to say the least to find out how easily this annoying problem can be fixed...
    V6 VR Acclaim
    Jun 2010
    Quote Originally Posted by someguy360 View Post
    Fair enough. Second hand pumps usually run in anywhere between $30-$80 depending on where you go and if they like to chuck obscene prices on them.
    Quote Originally Posted by Brett_jjj View Post
    But I suggest you do this first. If this doesn't work, ring around your local wreckers and see if they have any for a decent price.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Beat me to it
    Yeah the Bush is generally the source of the groaning. The pump groan/giving way is usually accompanied by some feedback into the steering wheel, rather than just a groaning noise.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by HamaTime View Post
    Beat me to it
    Thanks guys
    That sounds more likely to be the culprit
    The car was sitting for 3 years before I got it so the bush is probably very dry.
    Will spray some WD40 tonight and let you know how it goes
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'd put my money on the pump. The vanes wear and make a noise when it's under load. Does it make a noise when just idling and not moving the steering wheel?
    Visit my Facebook page
    VS Equipe
    Jan 2011
    Adelaide, SA
    Quote Originally Posted by Not_An_Abba_Fan View Post
    nope its only when turning the wheel.....and the noise doesn't seem to be coming from as far as the engine bay.
    Sounds more like from the firewall/closer to my feet...which is why I am thinking more and more that it is the bush that lots have mentioned
    Dec 2009
    It might not hurt to replace the fluid in the power steering as well especially if it has turned a dark red.
  1. [Ecotec] vy v6 powersteering.
    By psivyv6 in forum V6 Development And Modification
    Last Post: 07-08-2009, 10:23 AM
  2. powersteering
    By LTHL-VP in forum General
    Last Post: 29-04-2009, 02:55 AM
  3. powersteering
    By ultimate_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2006, 11:00 AM
  4. intermittent quiet brake groan
    By ciaranvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2006, 01:36 PM
  5. VH powersteering
    By PinkVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-07-2004, 11:11 AM
