Not sure if this has been covered before but will a vr solid diff exhaust fit a vs with a solid diff?
dont see why not not all VS have IRS
At 43 a wealth of info , but still heaps to learn
depends which part, the stock manifolds wont as they are spaced differently at the heads. As for the rest I thought the VR had a different flange setup then the VS.
Goodluck and let us know hwo you go.
The exhaust I have is from cat back, the manifolds r being left it's jst after the cat down to the end
Not sure if it is the same on all models but every VS I have delt with has had a male/female type flange with a rubber/wire gasket in the middle, like a big "O" ring, while the VR and earlier models used a flat faced flange to join from the cat back.
No, definitely won't fit. The cat is in a completely different spot and the flange is different. Just shortening the VR system won't work as the front pipe is a different shape as well. Only on V6's though, if you are talking VS V8, then yes, they are interchangeable.
Incorrect my freind some do and sum dont , it was available as an option on all modles and cost around $1500 . I came out as standard equipment on , acclaim , ss and calais , was an option on exec , s , and berlina heres a link for ya Holden VS Commodore / Calais
#### me, people have a hard time understanding English.....
