Results 1 to 2 of 2
Thread: NEED SOME HELP. VS commodore with ABS disk removal
    ViN3Y is offline V!N3Y
    97 HSV Clubsport
    Aug 2008
    Mildura, VIC
    Default NEED SOME HELP. VS commodore with ABS disk removal
    ok so im fixing some things for a mate on my week orf and have got to the rear wheele studs and am stuck with removing the disk to get to the hub due to the abs...
    ppl keep telling me it cant be done like normal but as far as i can c its no different...
    its a solid diff and has abs but surely you just remove the calipers and housings and then remove the disk then hub bash out the old bash in the new....
    can any1 help out PLZ...
    [SIGPIC][/SIGPIC]
    JU$T A$ L1F3
    97 VS HSV ClubSport
    VS Stato SII L67 S/C V6
    Apr 2004
    Yeah, the disc can sometimes be a bit of a tart to get off on the back, they often bond to the hub with a layer of rust. The way I got mine off was to bash, rotate, bash, rotate, bash, rotate, and eventually they started to come free. I thought they were never going to come off. As far as I'm aware the live axle version is the same kind of setup as the IRS version
  1. VZ single disk head upgrade to 6 disk
    By Ausdiver99 in forum Car Audio
    Last Post: 14-07-2010, 10:02 PM
  2. vn rear disk hand brake hub removal
    By waynerc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-06-2009, 04:35 PM
  3. VK Stock drum and disk setup to a VT disk setup
    By justinp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-02-2006, 09:37 PM
  4. VR Rear Disk Removal
    By Nathan 2951 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2006, 01:34 PM
  5. VS 95 wagon, diff / rear end disk - disk
    By digisol in forum Swap / Wanted to Buy / Trade
    Last Post: 27-11-2005, 06:05 PM
Tags for this Thread
