Just got a recon motor in and the trans just s**t itself 200km into running it in, it's a 4hdd but is there anything else i need to know, my mechanic said i need all the model numbers, just wondering why? and what alternative i have in regards to similar trans (5hdd etc). Thanks
Fairly sure the 5hdd is for the VS as that is an ecotec motor. You have a buick motor. Fairly sure the only gearbox as a replacement will be the 4hdd unless you want to go manual *hint hint*
If it's not a Symptom its not relevant, and if its not relevant I don't care!
cheers? Are all 4hdd's the same? I'd love to go manual but the mrs wont like it. stuff it i should do it anyway.lol
All 4HDD's should be the same...the 5HDD for the VS had a different plug which makes it very difficult to fit so try to get a 4HDD.
thanks for the help guys.
So i got back to the mechanic and he said there is a 4hdd (e) and a 4hdd (i) or (y) does anyone know the difference he didn't to seem to want to elaborate on it?? looking on here also the 5hdd is an option but just not using the extra pin or solenoid is it as simple as that??
Anyone? and how many hours to do the t5 conversion roughly, there is me and my brother and a third when and if needed??? Probably heading towards this option.
Could knock it over in a day or weekend, depending on the kind of tools, skills and equipment you have. Make sure you get a Manual tune and PCM before you start other wise you will be running into all sorts of problems.
