Results 1 to 12 of 12
Thread: vs v8 keeps dying then restarting within minutes
    vs berlina
    Apr 2009
    port pirie,SA
    Default vs v8 keeps dying then restarting within minutes
    hey guys,
    my vs v8 with a 6speed box keeps dying while driving then starts straight away again.some days it doesn't do it at all and some days like today it does it lots.
    You'll be driving along and then it loses all power.Today when it started first time ever it was making a clicking noise from the front of the motor and then it died again.I have been told it could be the oil pressure switch.Any ideas?it's giving me the s**ts
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    oil pressure switch wont make your car stall but i would be looking at the coil, ignition moduel and fuel pump
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Make sure your coil lead is securely attached to the coil and distributor.
    vr ss
    Jan 2011
    bathurst
    Check the return line for the fuel tank, my vr ss done something similar wen it was under load. Return line was clogged up and choked the pump. Remedy was a new return line and new pump.
    vs berlina
    Apr 2009
    port pirie,SA
    vs berlina
    Apr 2009
    port pirie,SA
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    By the sounds of it, it could be a hot electrical joint somwhere in the main harness. Try having a look around the relay bases and main wires in the relay box under the bonnet for starters.
    Reaper
    vr BT1 5l
    Mar 2011
    perth
    ticking before dying? if you have a fuel pressure guage, there not hard to make if you dont, plumb it in and check you fuel pressure, ive had similar issues with my shitbox. at first i thought it was the reg, but a freind of mine suggested fueling pressure issue. fuel pump was fingered.
    if it only does it when its hot, or stone cold, then id maybe lean towards the sensors divison. does it flash fault codes? if its starving and misfiring (ticking whilst running) it will get rather hot though.
    wouldnt hurt to check the timing, people with half a brain often dont tighten the dizzy enough (ive had 2 5l's now come in with timing up to the shithouse because the dizzys moved due to mullets not tightening the bolt. a cut down 14mm ringy fits just nicely inbetween the firewall and the back of the donk.
    hope this helps a little.
    vs berlina
    Apr 2009
    port pirie,SA
    Thanks guys.I'm about to give up i think.what'd do you think i'd make if i wrecked it?it has a 185i motor with extractors,new alternator,new ignition module,new radiator,starter motor,power steering pump,a 6 speed out of a 5.7lt vt,bodykit,mags and shit
    vs berlina
    Apr 2009
    port pirie,SA
    when it stops its like it loses power in the front.sometimes when you turn the key after it has stopped you don't hear anything from the motor all you hear is the electric fuel pump then you can turn it off and back on again and you hear the fuel pump again,all the clicking under the bonnet and it starts but really stinks like fuel.
    vr ss
    Jan 2011
    bathurst
    well, I hope you dont just part ways with it, BUT, if you do, let me know what you want fo the motor and gearbox.
    Brendo169's Avatar
    Brendo169 is offline HSV Porn
    VS Senator
    Aug 2009
    WA
    maybe take it to a mechanic and get them to sus it out if you can afford....dont just wreck its because its got a problem!!!!
  1. Intermittent stalling and restarting issues
    By Dannal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2010, 08:46 PM
  2. Hard restarting VR...1 hour wait.
    By Hotblooded_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2009, 07:00 PM
  3. Won't start for 10 minutes when hot
    By lepeyrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 08:28 PM
  4. 15 minutes of fame
    By Pretender in forum The Pub
    Last Post: 28-03-2006, 10:30 AM
