Hi all.
As title says my handle is loose and yes have done a search.
Took the trim off and can`t see anyway of tighting it.
Help.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
get a new door handle.
the handle comes apart in 2 pieces when its taken out of the car,theres a big pin the slides across the back of the handle to hold it together and lock it in to the door,id say its been taken out at some point and probably needs to be re bent to "tighten" it back up. well thats what ive gathered as mine is the same but i havnt gotten around to fixing it yet,could be wrong though
just to confirm are we talking inside or outside handle?
if outside the above post is spot on....mine were loose and i took the handle out of the door and had a fiddle around with big pin. they are a major pain to get back in the door!
My Senator 355 Stroker
http://forums.justcommodores.com.au/...5-stroker.html
Cheers Guys,
I know the pin you are taking about.
So I can take the pin off without disconnecting anything else?
Bend or get new one replace.
