Results 1 to 5 of 5
Thread: throttle cable.too tight if idles at 1500?
    96 vs executive s2
    Mar 2011
    Default throttle cable.too tight if idles at 1500?
    hey all,
    Just thinking if 1500rpm is to high an idle speed for my vs.
    I tightened it just a tad, i was just after a bit more response(guts).
    cheers.
    VR Series 2 EQUIPE
    Jul 2006
    Craigieburn, Victoria
    This sounds like the wrong way to do things.... if the cable is tight enough to go to its fully open position, then tightening the cable more will not do anything and end up causing you more problems...
    If you slack off the cable a bit, does the idle go down? If so, then you have the cable too tight. Idle should (in theory) be in the 725-850 range when warm...
    96 vs executive s2
    Mar 2011
    ill loosen it a little lol, last thing i need is more problems.
    just thought id see what happens, 1500rpm way too high.
    thanks.
    96 vs executive s2
    Mar 2011
    Let it loose a bit now down to 900 @ idle in park.
    good enough for me. Im thinking about getting a good flat panel filter and a cai.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    TPS sensor on right?
  1. Fixing tight throttle cable - easy peasy.
    By Circlotron in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2011, 06:23 PM
  2. how to make your accelerator cable tight
    By vnwpn2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2010, 05:28 PM
  3. T/B only opens 80% when kickdown cable is tight
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2008, 03:31 AM
  4. Accelerator cable tight
    By wetwork65 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2006, 10:38 PM
  5. Kick down cable too tight - restricting full throttle; HELP!
    By vq~gangsta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2005, 05:33 PM
