Results 1 to 17 of 17
Thread: Vs front spring removal
    VS EXECUTIVE
    Mar 2011
    Default Vs front spring removal
    Hey guys Ive seen a lot of posts on here saying to use a spring compressor, but my mate swears i dont need one, just wondering if his right or wrong.
    Thanks
    Will
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I've done it without one, but only if fitting lowered springs. With the car on the ground, remove the top nut, the metal plate, then the nut under that. Slowly jack the car up until the spring is loose. Then remove the strut as per normal.
    If you are not fitting lowered springs, you will need compressors to get the spring back on. Otherwise you can push the spring down enough to get the nut on when fitting lowered springs.
    Visit my Facebook page
    VS EXECUTIVE
    Mar 2011
    vr
    Jun 2009
    springs under tension can and will kill you if something happens and they are not contained. dont be cheap. get a pair of spring compressors for about $50 from most auto shops. very very risky not using them.
    Quote Originally Posted by v6monstar View Post
    dude your piston slapping your going to have to titan up your pistons be for you throw a con rod throw the side of the of your engine
    vs commodore
    Oct 2009
    Tamworth NSW
    I agree,very dangerous to try to remove/fit them without spring compressors,a spring has a lot of energy stored in it when its compressed onto the strut,and as mentioned,more than one person has been killed before trying to remove/fit springs without the right tools.
    VS EXECUTIVE
    Mar 2011
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Bullshit. Show me some evidence where people have been killed removing springs.
    The springs are retained by the car, there is absolutely no chance the spring can fly out. 40 minutes to replace both front and rear springs, start to finish.
    It is actually more dangerous to use spring compressors as they can slip if you haven't got them on properly.
    VS EXECUTIVE
    Mar 2011
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Yep Crack the main bolt first, Jack the car up etc etc.... We hold no responsibility if you put yourself in hospital if you do hurt yourself though.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VS EXECUTIVE
    Mar 2011
    okay thanks a heap so what should i be aware of going flying in the air haha?
    1996 Vs Berlina
    Dec 2010
    narre warren
    My mate reckons he used a bunch of zip ties instead of spring compressors, but apparently you can get away without needing them, i've only ever done rear springs
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    Quote Originally Posted by Not_An_Abba_Fan View Post
    from what i can gather,your talking about undoing the tops while its all still in the car,you couldnt undo it all once you had removed it complete from the car without compressors as a standard spring would more than likely take your head off...
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by Adds_05 View Post
    Yes you can, undo the main nut, remove the plate then undo the next nut. Jack the car up slowly until the spring decompresses, there is no tension on anything and nothing can fly out.
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    yeah thats what i was meaning when i said "from what i can gather,your talking about undoing the tops while its all still in the car",
    where i said "you couldnt undo it all once you had removed it complete from the car without compressors as a standard spring would more than likely take your head off",i meant it as,if you took the complete spring and shock out as one with it NOT undone like the way you suggested,it would take your head off if you then undid it
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    "Bullshit"you reckon,What a stupid naive attitude to have,just goes to show why people do get injured/killed sometimes.Ive seen a couple of newspaper reports over the years where a car spring has killed someone when theyve tried to remove them without the proper tools.Yeah,Its rare, but the point is it can still happen...especially if the person attempting the work is inexperienced.The only way spring compressors can be dangerous is if they are not fitted properly or not used properly ,or if the operator tries to compress the spring too far,the springs only need to be compressed enough to take the tension off the top mount so the piston rod nut can be loosened and removed...Ive used a few different types of spring compressors over the years and I have never had a problem with any of them..This reminds me of this guy who worked fitting truck tyres,he was told to pump them up in the steel cage so that if the steel locking ring flies off,then he wont get hurt or worse,this guy used to say,ah,shes right,ive done it heaps of times and never used the cage whilst pumping the tyres up,so shes all good,next thing he was killed by a locking ring that flew off.Theres always someone who doesnt listen...
  16. #16
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I reread what you wrote, yep, know what you meant now.
  17. #17
    VS EXECUTIVE
    Mar 2011
    Hey these are the results
  1. Front Spring Issue?
    By Toddlez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2009, 10:09 PM
  2. vx ute front spring code
    By steak in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-08-2009, 06:45 PM
  3. irs spring removal
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2009, 08:03 PM
  4. coil spring removal query....
    By roon_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2008, 03:16 PM
