Results 1 to 14 of 14
Thread: my auto wont change gear
    NONE
    Feb 2011
    Alaska
    Default my auto wont change gear
    hey guys, had my vr berlina for a fair few weeks now and ive noticed that if i pin it too the floor itll rev out and wont change up gears till i back off slightly, but if i keep the throttle slightly off the floor it changes fine, any ideas as to what it could be?
    Haters gon' Hate
    VR Senator
    Nov 2010
    NONE
    Feb 2011
    Alaska
    ss Thunder crewman
    Aug 2009
    ok start ya car & check the dip stick for the auto & see how much transmission fluid you have if its on the full mark check what colour the fluid is if its red good if its brown or black
    thats not good but if ya not to cluey on things like this take it to a good automatic transmission specialist it may need a good service
    NONE
    Feb 2011
    Alaska
    just been recond by a mechanic before i bought it so im assuming it'd be ok but ill check. was just asking to see if its something that just needs ajusting but if its not ill def take it to a mechanic
    Haters gon' Hate
    VS l67 statesman
    Dec 2008
    VS Executive S2
    Oct 2010
    Central Victoria
    Mine had this problem, Would also backfire on gas, There was a sensor near the Crank that was Cracked ( not the crank angle sensor ) that was the problem. When i asked about it everyone said TPS so that could also be the case.
    Hope this helped and Goodluck!
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Quote Originally Posted by Crewmanss 06 View Post
    check what colour the fluid is if its red good if its brown or black thats not good
    Lol Ur joking right?
    The fluid will go brown straight away, Lols
    Same with engine oil, doesn't stay the colour it was when u put it in
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As Vsl67 says it classic Throttle Position Sensor failure...the auto thinks the throttle is still closed when it's fully open - about $60 to replace. Re the fluid colour - it should stay red till the bands/clutches slip and overheat enough to burn it....mine is still red 100,000km after overhaul which tells me it's still tight, but once it goes brown it will be a sign that it's getting worn again.
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    Hako is 100% correct, a correctly working auto should keep its fluid cherry red and smelling wonderfull, often the transmission fluid will smell "burn't" before it loses it's color.
    The throttle position sensore is easy to change and to obtain, I suggest buying a Gregory's or a Haynes manual from your local auto shop. Remember to keep your auto running perfectly for longer, service it every 20 thousand, its not a difficult job and doesn't cost much either.
    NONE
    Feb 2011
    Alaska
    vr commodore executitve, manual vn executive
    Mar 2011
    sydney
    my atf is black what does that mean? and same thing is happening to me gotta use the pedal lighty or it will go up to 4000rpm goin off the lights
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by brend94vr View Post
    It probably means your transmission is about to fail....which means you will be sitting on the side of the road. To avoid this, you need to decide if you are just going to drive it till it dies, or drain and flush the atf with a new filter and a can of trans no slip and hope that this will delay the day it dies or finally, go to a trans shop and get their advice, which will be that you need a reco trans...$2000 or thereabouts.
    The more you drive it the worse it will get as the slipping overheats the oil which then degrades the oil etc.....
    Mine failed 1500km from home, and it wasn't a pleasant experience.
    Good Luck.
    94 VR Executive & 99 VT XU8
    Mar 2005
    Melb
    firstly, check/replace your CAS (crank angle sensor) / TPS (throttle body positioning sensor).
    following that, suss out your auto fluid levels/condition (if its any color but cherry red - your autos probably toast) and if needbe be prepared consult a pro.
    94 VR V6 - No ABS & NO IRS... a true mans steed and a 99 VT XU8 for good measure.
  1. Gear Change Auto
    By ufo8mycow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2009, 11:28 PM
  2. Auto gear change...
    By BustedNut in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-12-2008, 08:26 PM
  3. Vn auto wont change out of 1st gear
    By Cameron in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2008, 11:35 AM
  4. VH 253 auto wont change out of 1st gear
    By jimmyd17 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-12-2005, 09:33 PM
  5. Changed my trans fluid finnaly, now car wont change gear sometimes.
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 08:59 PM
