Results 1 to 5 of 5
Thread: Car Idle's to 200rpm in park
    VK Commodore
    Dec 2010
    Townsville, Australia
    Default Car Idle's to 200rpm in park
    i own a 1995 VR Calais and it starts then it will idle up to 2000rpm in park and then drops down then the engine dies?????????
    can someone help
    VS l67 statesman
    Dec 2008
    vs commodore
    Feb 2011
    perth
    200 rpm in park?does it sound like it has a cam in it? Then you will have to check the vacum line underneath your throttlebody. it will hook up with the purge canister solenoid at the back of motor. Check all the vacum lines running off that.
    Failing that take out IAC and give it a clean.
    VK Commodore
    Dec 2010
    VK Commodore
    Dec 2010
    nah it is a stock with V6 commodore and i have just done a service and top end gaskets on it,
    ill start the car and then it rev's its self to 200 rpm and then drop then die
  1. Should you rev a Ve in park..
    By TheVESV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-11-2010, 07:08 PM
  2. Don't you wish you could park like that!
    By Reaper in forum The Pub
    Last Post: 17-08-2009, 12:57 PM
  3. Flatspot Between 200RPM-3000RPM & A Power-Surge.??
    By Lethal_1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2008, 08:34 PM
  4. is this right.....200rpm
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-02-2006, 09:52 PM
  5. rough at 200rpm
    By Sick Blue VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-09-2005, 02:16 PM
